Results 1 to 5 of 5
Thread: KDF11 board question
    Default KDF11 board question
    All --
    I pulled an 11/23 CPU card out of my storage in advance of trying to put an 11/23 system together. The card, M8186-YA, should be the 11/23 CPU with the MMU (allowing for a 4MB memory, I think). My board has two empty chip spots, rather than one -- most images I see on-line have two chips that have two gold-topped chips (I don't know what to call these kind of piggyback chips). Is the second the MMU chip? Or maybe the FPU?
    Any info appreciated. Thanks!
    Rich
    That extra chip is the floating point microcode. The actual FP registers are in the MMU chip.
    http://gunkies.org/wiki/KEF11-A_floating_point_chip
    Thanks Mattis. So if the third chip is the FP chip, what's the fourth socket (second from left with the card edge down) for?
    I believe that's for the Commercial Instruction Set, an extension which added BCD and string instructions to the 11/23, 11/24, and 11/44. No idea how common that ever was.
    Computers: Amiga 1200, DEC VAXStation 4000/60, DEC MicroPDP-11/73
    Synthesizers: Roland JX-10/SH-09/MT-32/D-50, Yamaha DX7-II/V50/TX7/TG33/FB-01, Korg MS-20 Mini/ARP Odyssey/DW-8000/X5DR, Ensoniq SQ-80, E-mu Proteus/2, Moog Satellite, Oberheim SEM
    "'Legacy code' often differs from its suggested alternative by actually working and scaling." - Bjarne Stroustrup
    The KEF11-B CIS microcode is a double size module so you could not have it simultaneously with the KEF11-A floating point option on the KDF11-A. The quad size KDF11-B has 5 sockets so on that you could have both CIS and FP.
    http://gunkies.org/wiki/KEF11-B_CIS_chip
