Unless you need to move the disk from machine to machine, you can just take a disk that you think was well written and use your scope to get the best read. If single sided, make sure the pad on the back side id clean and even pressure across the head or you'll be adjusting for a bad pad.
Make sure everything else is working well, like the speed is correct under load.
The schematic on bitsavers shows two pots. The R23 looked to be the write bias current adjust. Do look at where the leads go before adjusting anything. The speed goes to a oneshot. The current adjust goes to the transistor pack DIP.
Dwight
