I'm looking for anyone who has any of these three systems and who might be able to extract dumps of the on-board serial ROM.
In brief, the 8k SROM is the first stage boot code, and its loaded into the primary instruction cache at reset. It performs some diagnostics, and loads the second stage from Flash into RAM and starts it.
The SROM device is apparently a Xilinx XC1765 "serial configuration PROM", normally used to configure FPGAs, so might require something other than a standard dumping device.
In addition, ROM dumps from the Flash memory and/or any installed EISA peripheral cards would also be very helpful.
Appreciate any/all leads, sincerely,
Patrick.
