Results 1 to 3 of 3
Thread: Quadram Quadboard / LPT printer adapter cable with 16 DIP header
    Default Quadram Quadboard / LPT printer adapter cable with 16 DIP header
    I have a Quadram Quadboard memory expansion card (4x64k, RTC, COM, LPT) which requires a separate cable and adapter for the parallel port. The special feature is that the adapter on the card has to be plugged into a 16 DIP socket. Does anyone have further information?
    May 2006
    Melbourne, Australia
    6,100
    Post #7 at [here] appears to have what you are looking for.
    Thank you for pointing that out. I found a picture of the 16 pin card adapter which should show the correct numbering. It is also a Quadboard. The problem should be solved.
Tags for this Thread
