Results 1 to 7 of 7
Thread: Compaq Portable - Help
    Default Compaq Portable - Help
    Hi to everyone. I am searching this kind of transistor (photos). I dont know the type of transistor and i cant find any info. Can somebody help me? This Psu is from a Compaq portable https://i.ytimg.com/vi/2YO-BCqPqs4/m...lt.jpgcomputer . Do you know if schematics are available for compaq portable?
    Thank you in advance.
    Default Service manual
    Here found somewhere else on this forum. Not very helpful for Q3 though. Lists it as a 508 with no replacement data. Hope it helps with the detective work.
    http://download1321.mediafire.com/qb...+-+cscs-15.pdf
    You could try purchasing the SAMS computerfacts for the compaq portable. They will most likely have a schematic for the PSU in them.
    I had a look on SAMS website and they still offer it for $22. Link here
    Feb 2009
    Chattanooga, TN - USA
    892
    Ok, so no clue on the cross, apparently I chose poorly last year, which is why my repair failed.
    It's labeled just 508.
    Here's a link to the service manual.
    http://www.svfdtn.com/mtx/Compaq%20P...e%20Manual.pdf
    Later,
    dabone
    Based on the schematic posted above it's just a BU508 power transistor. Still readily available.
    Hey guys. Thank you very much for the support. I was looking for this pdf but i couldn’t find it. Thank you very much. Before i read your answers i replaced the transistor with BD139 and i also replaced the diode next to it which was bad. After i replaced these components the psu worked with all voltages. Unfortunately one tantalum capacitor on cga exploded so i have to replace all these capacitors. Now with this pdf i will examine better the psu and i ll check all the computer.
    Thank you again for the support all of you. !!!!!
    Hello, I have a problem with an identical power supply. The power supply starts and has the correct voltage for 20-30 seconds after which it power off. If I power on the power supply without load , the voltage tend to remain stable, but as I add a important load(big HDD) voltage begin to fall and the power supply stops. I changed the capacitors on the output but in vain.Some suggestions?
