Results 1 to 9 of 9
Thread: missing Atari ST key
    Sep 2017
    Principality of Xeon
    1,861
    Default missing Atari ST key
    I assume I need only the actual key (it's early, not totally sure). Can anyone provide a replacement?
    Ok shined a light on it, clearly the plunger is missing a piece, duh, so I guess I'd need that too.
    I tried, sort of, to pop a different key off, didn't happen, and I'm askeered I'll break another one. Need a puller. It should just pop off, no?
    Ok plungers are available and not too expensive. I'm not paying 10 - 15$ for an individual key though. I have half a mind to try and cast one.
    Jan 2012
    Connecticut, USA
    2,721
    good luck, i gave up after months of no replies and bit the bullet and bought one.
    Dec 2016
    New Jersey
    285
    Before you put a new key on there you need to take all the other keys off and clean that nasty board! Yuck.
    34,128
    Plastic gets brittle. When I had a 520ST, I pulled all of the keys off to install "booster springs". Now, of course, the plastic has deteriorated and could well break.
    (cue: Shel Silverstein)
    Apr 2018
    Los Angeles, CA
    920
    Yeah, you can easily 3d print a new plunger but I don't see anyone that has already created that model for the ST, so you'd pretty much have to remove one and model a new one. The problem of course is the key, which isn't really a good 3d printable part (you could but it would look super ghetto). Like Verault, in every case where I've been missing a key, i eventually broke down and bought a new key. For broken plungers, i've 3d printed new plungers (originally for my Apple iie) but even those were eventually replaced with original plungers because I didn't like the feel of the 3d printed version (I don't have the best 3d printer). But generally, plungers are the perfect use for a 3d printer and the route we'll all have to take when parts run out.
    -- Brian
    That's the Alternate key, and it looks like this eBay listing has one available:
    https://www.ebay.com/itm/132832006475
    That listing appears to be just for the key cap, but you can buy the plunger separately:
    https://www.ebay.com/itm/153341614716
    Apr 2018
    Los Angeles, CA
    920
    Yeah, you can, but he also said in his post that he wasn't going to pay $10 for an individual key cap, so I'm assuming it's that auction he was referring to. That said, there aren't really any other options.
    -- Brian
    Feb 2011
    2,384
    10
    I might have one. I have a keyboard thats damaged at the other end, but being in the UK postage is likely to be several $....
    G4UGM
    Have you reached out to Best Electronics or B&C? They might have a replacement or whole replacement keyboard. Make your ST like new again.
