Originally Posted by
Zippy Zapp
The monitor, c64 and the datassette are not usually capacitors that need to be replaced. With the monitor I think one of the common issues is cold solder joints or cracked solder joints which can cause flickering or interference on the screen. I have not replaced any cap in my C64's, 128 or Amiga 500's nor any drives. Someday I am sure I will need to replace them all. But these aren't the caps like they put on the later Amiga's and Macs, SMD junk that are prone to leaking.
I have actually removed the caps in one 64 original model that I was junking because of a damaged board and every single one of them were still in spec and had no problems.
