Results 1 to 10 of 16
Thread: Help with power supply for Mitsubishi Model M2896 8" Drive
    Feb 2012
    Fort Walton Beach, Fl
    508
    Default Help with power supply for Mitsubishi Model M2896 8" Drive
    I have a model M2896 Mitsubishi 8" diskette drive, I have the following setup below.
    I have a DBIT power adapter and a DBIT 50 to 34 pin cable adapter. On Chuck G's advice I have tried to operate the Drive with an Adaptec Drive with a floppy controller, Sergey's FDC controller board as well as an XT-FDC board from the forum. All of them work.
    I am trying to assist a friend who is trying to setup the same basic configuration with a Shugart 851. He is hoping to find a less inexpensive option that the DBIT adapters. I found a 50to34 PCB that think will work.
    Can I use a MEAN WELL AC-DC Power Supply Dual Output 5V 24V, that you find on Amazon, with the correct connector for the Shugart Drive.
    Thanks,
    Jimmy
    Looking up the power requirements for the SA851, I see 1 amp for the 24V and 1.1 amp for the 5V. If the supply you are looking at is rated for that or more you should be OK.
    Dec 2005
    Toronto ON Canada
    7,349
    Don't overlook DC-DC boost converters; this is what I use for my Tandon TM-848s, but there are lots out there.
    https://www.ebay.com/itm/1x-150W-Boo....c100005.m1851
    If boosted from 12V it is about 2.5 to 2.75 amps extra.
    34,320
    I've also used a standard 5+12 VDC supply with a separate 24V supply. In any case, it shouldn't be too hard--there were lots of open-frame 5+24V supplies in the day.
    I've got a couple of 230v... +5V 50A, +18V 3.8A, -18V 3.8A supplies. Gonna make an electric chair with one.
    Dec 2005
    Toronto ON Canada
    7,349
    Yeah, I've also got a few of those but when the system is a PC or otherwise with an AT/ATX supply with lots of amps then the $4.00 converters are very convenient.
    I've got a 400W ATX supply in an S100 box to power two ST-4096s and the floppies, including the TM848 using one of those.
    You can also float a 12V on a 12V grounded supply..
    http://minuszerodegrees.net/temp/3/temp_65_85892.jpg
    I kept that link for reference for the connector.
    34,320
    Be aware that a few very old 8" drives also specify a -5V supply (but not the one the OP specified).
