Page 1 of 2 12 LastLast
Results 1 to 10 of 17
Thread: Gotek Emulator as Primary Floppy Drive for IBM 5150
    Default Gotek Emulator as Primary Floppy Drive for IBM 5150
    Hello all, I am brand new and trying to figure this out. I can find no info anywhere on the net except for one youtube video mentioning it as a possibility. I have been able to remove the primary floppy drive and attach it via jumper wires to the floppy ribbon cable. I have a usb drive in formatted as 720k with pcdos 3.3 loaded on. When starting, the the green light on the emulator stays illuminated and the usb thumbstick light blinks, but the 5150 just boots into cassette basic. The secondary floppy has its read light on, which it doesn't do when the regular floppy drive is installed. Is this something that just isn't possible or could I be missing something? Thanks for any help.
    This is the drive I purchased https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    And the 5150 looks to have the third bios revision.
    Mar 2013
    Chaffee, MO
    1,445
    It sounds to me like you have the drive select jumper set incorrectly.
    If you have a Floppy Cable with the 10-16 twist in the last connector, then both floppy and GOTEK need to be
    strapped for Drive 1. (The twist in the last part of the cable makes the GOTEK Drive 0, the one that should boot.)
    The GOTEK jumpers are:
    Possible Jumper settings for Drives (0..1)
    J5 = ---
    JA = Jumper to generate READY signal on 34pin of floppy driver interface
    JC = ---
    JB = ---
    S0 = Jumper for Drive select 0
    S1 = Jumper for Drive select 1
    MO = Jumper for Motor
    So, for your Boot GOTEK at the end of the cable, you need JA, S1 Jumpered.
    If you have a straight through cable, then the GOTEK, will need to be jumpered for Drive Select 0.
    Your Boot GOTEK at the end of the cable, you need JA, S0 Jumpered.
    Is this what you have?
    You can also change the FIRMWARE, from the original to FlashFloppy or the HxC Firmware.
    The HxC firmware does cost around $12.00 USD for each unit you modify.
    Larry
    Last edited by ldkraemer; February 23rd, 2019 at 05:02 AM. Reason: addded firmware info
    Mar 2013
    Chaffee, MO
    1,445
    I just checked my photo of the Jumpers I have on my DOS 7.x GOTEK, and you also need to
    Jumper the Right Side of the Jumper Block (with 34 Pin Pins on your left) JA to J5.
    I think the JA/J5 jumper is just a way to hold on to a jumper. I think both pins are ground.
    Thanks guys. Yeah I have tried all of those combinations and it wont boot from it. Ive converted from teh molex connector to 4 pin to power the drive, and Im wondering if I need to bring that down from 12v to 5v and that maybe that is causing the problem. The other thing Im wondering is that it just wont work with a 1.44mb drive even though Ive formatted the flash drive for 720k disks. I cant find anywhere what the light combination means, but when it stars in some jumper configs, the green light stays on, and the 2 periods on the right blink with 000 displayed. I might try flashing the other bios and see if that helps.
    Mar 2013
    Chaffee, MO
    1,445
    Alan2,
    Well, I don't think so. The JA Jumper goes directly to the IC U3 Pin 38 labeled PC6. And the J5 Jumper goes two places, to Pin 4
    of the 34 Pin Header and also to the 16 Pin IC (that isn't labeled) to Pin 1. Then through that IC to Pin 2, which goes to Ground (Vss).
    I'll have to find out what that IC really is. Also Pin 4 is PULLED UP to +5 VDC by PU2 a 1K Resistor.
    Larry
    Hi Larry,
    In the picture above, the jumper over the J5/JA that is on the right side and vertical is on ground pins. If you flip the board over, these two pins and the two below them are all grounded, so J5/JA/JC/JB right side pins in the picture are all grounds. I'll bet the jumper only matters if it is placed horizontally over J5, JA, etc.
    Thanks,
    Alan
    Does the 5150 not require a 720K Gotek?
  9. #9
    34,136
    18
    If you stick with the Gotek native firmware, yes. If you load it with third-party firmware, such as FlashFloppy, then a 1.44M Gotek will work fine.
  10. #10
    I got it working! Thanks for the help guys. Ordered a different cable and that helped, along with flashing flashfloppy all is well. Now I just need to find a cable with twist at the end with the IDC connector after the twist and a card edge before the edge so I can use the floppy drive to backup floppys and use them in that drive. Thanks for the help everyone!
    And to clear up the jumper situation, I used the config here https://github.com/keirf/FlashFloppy...atforms#ibm-pc, and it worked perfect. May have to change it when I put the other floppy drive back in line though.
