Page 1 of 2 12 LastLast
Results 1 to 10 of 16
Thread: Sinclair Spectrum CP/M 2.2 - Creating Fuse Compatible Disk Images
  1. Default Sinclair Spectrum CP/M 2.2 - Creating Fuse Compatible Disk Images
    Hello,
    I've been experimenting with CP/M 2.2 on an emulated Spectrum +3 using the Fuse emulator,
    but am having problems creating disk images for it.
    I have been comparing basic benchmarks across computers and would love to run the benchmark
    I have written using basic-80 (mbasic) on the Spectrum under CP/M. I've tried using P3Explorer to
    create a .DSK image which has mbasic.com and my bench.bas on it, but while I can type bench.bas
    and everything seems to display properly, when I run mbasic.com the emulated machine just reboots.
    The docs for the Spectrum version of CP/M 2.2 say that it has been tested with Basic-80,
    so I'm assuming it is some problem with the way I'm creating the image.
    If anyone has any ideas I would love to give them a go.
    Best wishes
    Lorry
    TechTinkering
    Retro computers, Programming and General Technical Tinkering
    Latest Article: Benchmarking Basic on Vintage Computers
    Lorry,
    I'd like to try your image in the MAME emulator. Can you post a disk image with your test program and MBASIC already injected?
    Yours
    Robert
  3. Default
    Quote Originally Posted by rfka01 View Post
    Lorry,
    Here are two links:
    .dsk image with just mbasic.com and mbasic.bas - this hangs when you run mbasic.com
    .dsk image with partial cp/m 2.2 plus mbasic.com and mbasic.bas - this resets when you run mbasic.com
    I don't know if the image format is compatible with MAME though.
    TechTinkering
    I can confirm the behaviour you experience ... but there's something strange going on: Your disk images refuse to boot in the MAME Spectrum +3 emulation, prompting for tape loading instead.
    I can boot from the original disk you linked to in your first post, though. I can mount your modified images as drives B:, and if I use P3 explorer to add MBASIC to a working image, I get the tape message as well.
    P3 explorer might be to blame.
    Robert
    There's nothing wrong with the disk images or FUSE - if I boot from the official +3 CP/M Plus, and then insert these discs, MBASIC works just fine. (It also works under PCW CP/M in JOYCE). I'd be inclined to suspect a bug in the +3 CP/M 2.2 BIOS.
    I can, again, confirm John's results: MBASIC executes when run from +3 CP/M Plus in MAME.
    A disk modified by P3 Explorer refuses to boot, a disk modified by CPCDiskXP retains its ability to boot, but MBASIC's not running. I also get R/O errors when I try to copy files onto the CP/M 2.2 disk.
    Robert
    Something just caught my eye from Lorry's original post:
    BASIC-80 does INDEED run on 2.2
    Robert
  8. Default
    Quote Originally Posted by JohnElliott View Post
    Thanks, in that case I'll try to see if I can get CP/M+ for the +3.
    I did briefly think of using JOYCE to verify the image, but must have got sidetracked.
    Incidentally, I ran this and another version using JOYCE that makes use of being able
    to peek(64504) to get the clock and was pleased by the performance of the PCW.
    TechTinkering
  9. #9
    Here's your benchmark on my MFA Mikrocomputer (8085@2MhZ, 64K RAM).
    Robert
  10. Default
    Thanks, that's great. On average it's just slightly ahead of the Sinclair QL. I've added it to the list: Benchmarking Basic on Vintage Computers, in case you haven't noticed it in my signature.
    Lorry
    TechTinkering
