Results 1 to 7 of 7
Thread: PDP-11/34 and PDP-11/73
    Default PDP-11/34 and PDP-11/73
    I am selling a PDP-11/34, as well as a PDP-11/73.
    The 73 contains an RL02, dual 80mb 8" Fujitsu hard disks, a tape drive, and KDJ11-A CPU.
    The 34 includes a Kennedy 9100 9 track drive, and has two UNIBUS backplanes. More will be posted about the 34 later.
    Please text me at *removed*. Please make an offer.
    Mod Note: Please do not post phone numbers and what not in the open forum, send it via PM if needed.
    Items are located in Houston, TX. Local pickup only.
    The 11/34 contains a J-11 CPU, a second backplane, as well as two BA-11LE chassis with backplane as some kind of slave configuration to the main computer.
  3. Default
    Are you providing shipping? Are these systems in a rack? If you are not providing shipping what are the dimensions of the system (rack if they are racked) also how much does each individual component/rack weigh?
    The 34 has two custom multiprocessor bus backplanes, and uses a J-11 CPU. It is on two standard 6ft racks, each weighing over 300lbs.
    The 73 is also over 300lbs and is about 22x32x42 inches.
    Shipping is via freight of the buyer's choice. P_20190311_212706_vHDR_On.jpg
  5. Default
    Do you know if these are functioning machines or are they untested?
    The 73 CPU works. Everything else on that rack is untested. The 34 is completely untested. Please make an offer if you are interested.
    The PDP-11/73 has been sold, along with the Fujitsu hard disks. The rack, RL02, and tape drive are still available
Tags for this Thread
