Results 1 to 8 of 8
Thread: Computer requirements to run “old” software
    Default Computer requirements to run “old” software
    It has been years since I last accessed a prgram and I am lost on what I need to have to be able to run / access the prgram and data.
    It is LINEUP a Baseball Card Inventory And Value System Program issued bu Emerald City Sports Cards. Copy right 1988, 1989. It is on 3 1/2 flppy. Besides the prgram I have some Update disks and a couple with the data stored on them.
    The Prgram Disk notes it is IBM Version 3.0.
    I know I used the program through around 1992.
    My current computers are Macbook Pro and a Sony Vaio (PCG-GRT Series Notebook runnin windows XP).
    I tried to access / read the floppy using an external floppy drive but I keep getting a message that the floppy needs to be formatted.
    I would appreciate any tips / recommendations, etc. I have 1000s of cards that I do not want to have to "reinventory" .
    Thank you in advance for your assistance.
    Feb 2017
    Chilliwack, BC, Canada
    535
    These days, MACs can read DOS formatted disks, so you should have been able to read it on either system. I'd say that most likely either the disk has gone bad, or your external floppy drive has. You could try looking online at abandonware sites to see if anybody has a copy of the program.
    My vintage systems: Tandy 1000 HX, Tandy 1000 RSX, Tandy 1100FD, Tandy 64K CoCo 2, Commodore VIC-20, and some random Pentium in a Hewitt Rand chassis...
    Quote Originally Posted by ndfly View Post
    I get that message quite often when using an external floppy drive and it's rarely the disk, itself. It's usually a quirk in the USB drive/Windows combo setup since when I check the disk in a normal floppy drive it reads just fine.
    See if you can configure the notebook to boot from the external floppy. If you can, boot the notebook from a DOS disk and then see how it reads the Baseball Card disk.
    Otherwise, you'll neet to put that disk in a machine with a real floppy drive to verify its integrity.
    Thank you. I need to try some other floppies that I still have - not related to this program.
    Thank you. As I repled to another who responded I think I need to try some other floppies in the external drive. I had been considering buying an older machine with a 3 1/2" floppy drive reader.
    3,568
    From 1988 it is probably 720k low density, and many cheap USB floppy drives don't support 720k like they are supposed to.
    Feb 2009
    Chattanooga, TN - USA
    911
    I converted a copy of this for someone last year, It ran fine under dosbox, so it will run on your mac after you get the data off the floppies.
    Where are you located?
    Later,
    dabone
    Located in the Maryland burbs of Washington DC
