Results 1 to 10 of 25
Thread: Amstrad PCW 8256
    Apr 2018
    Los Angeles, CA
    464
    Default Amstrad PCW 8256
    Hi All,
    I was given an Amstrad PCW 8256 the other day as not working, so I finally took a quick look at it yesterday. When it turns on, the disk drive spins and the light comes on, then the screen comes on and is completely green. I don't have any disks but I'm curious if this is normal before booting or if it should be displaying something. I assume i'll have to do some kind of Gotek solution or find some 3" disks to actually use it, but I'm just trying to figure out if this is a repair project or expected behavior so I can figure out the next steps.
    Thanks!
    -- Brian
    Working Systems: Apple IIe/II+/Mac+/Mac 512k, Atari 800/520STFM, Commodore 64/Amiga 3000/SX-64, IBM PS/1 2121-B82, Kaypro II, Tandy 1000 SX, TI-99/4A, TRS-80 Model 4 GA
    Project Systems: Amstrad PCW 8256, Kaypro 2/84 (Bad Chips: 81-194, 81-189).
    30,345
    Sounds about right--the screen is graphics only and so needs to load the OS before you really see any text.
    The system does look for a READY/ signal from the boot drive.
    Nov 2017
    UK, South East
    181
    It's the drive belt that needs replacing.
    Open it up and you'll find the drive belt has melted into a sticky black goo - clean it all up and replace the belts and the machine will boot from disk and clear that bright green screen.
    30,345
    He doesn't have any CF 3" disks--and they're pretty hard to come by in the US.
    However, with some care (particularly with the power connector), a 3.5" 720K drive works just fine (you will need that READY/ signal, so a 1.44M drive like an SFD-321B jumpered correctly will also work).
    Apr 2018
    Los Angeles, CA
    464
    Okay, great, I'll give that a try. I'm assuming there are disks on the net I can just IMD with a PC onto a 720k disk? (meaning not some crazy format like the Mac's that won't image on a PC?).
    -- Brian
    30,345
    The format is pretty tame with no surprises. But watch out for that power connector! It may look the same as a standard 3.5" power connector (4 pin), but the +12 and +5 lines are swapped. Unless you correct that, you'll let the magic smoke out of any 3.5" drive.
    I'm pretty certain the mod is covered somewhere on the web.
    Jul 2017
    Portland, Oregon, USA
    183
    Quote Originally Posted by ngtwolf View Post
    I'd avoid even trying to use a regular 3.5" drive and just go right to Gotek... Although I suppose if you can put in a Gotek you can also put in a 3.5 black drive. Now, can are there disk images to use with the machine via a Gotek or 3.5" drive? Hmmm.
    -- Adrian
    30,345
    I can probably create a few 3.5" IMD images if there are none from our UK friends available.
    Apr 2018
    Los Angeles, CA
    464
    Let me check around and if I run into problems I'll likely take you up on that. And thanks for the warning about the power connector, I might not have caught that.
    -- Brian
    Apr 2018
    Los Angeles, CA
    464
    Quote Originally Posted by misterblack View Post
    Yeah, as you saw yesterday , it doesn't look like either would fit as is, so I'll probably have to do the gotek with a replacement 3d printed mount. For now though I just want to confirm it's working before I proceed on about permanent solutions. It's also possible I don't care that much about actually using it (considering that kaypro, Osborne and even the trs-80 can do CP/M) and might just leave it stock. It's a nice looking system, as is.
    -- Brian
