Results 1 to 2 of 2
Thread: KDS 19" VS-190i High Resolution CRT Monitor
    Jan 2013
    Lake Havasu City, Arizona USA
    224
    Default KDS 19" VS-190i High Resolution CRT Monitor
    I'm not sure if there is any interest in someone acquiring this Monitor because the Shipping on it is going to be a little pricy.
    The Original Box is 23" X 25" X 22" and the Weight will be about 55-60 lbs. when packed. I can use USPS, UPS or FedEx Ground, but I suspect either FedEx Ground or UPS would be the cheapest.
    The Original Box DOES NOT have the Original Packaging, so I will need to put some kind of Padding in the Box as well which will be an Additional Cost if I have to buy something to use.
    Let me know.
    Jan 2013
    224
    If someone wants this, just pay for the Packing Materials & Shipping and it is yours. Let me know ASAP or it is going to the Recycle Yard.
