Results 1 to 10 of 16
Thread: Mechanical memory (and logic gates)
    Default Mechanical memory (and logic gates)
    Based om some publications, I tried to recreate 3D-printable mechanical components as they could have been implemented in the Zuse Z1, Z2 and Z4 mechanical programmable calculators (computers according to some). The logic gates were only used in the Z1, but the memory cell was also employed in the Z2 and Z4. The latter even had 1024 * 32 bits!
    See https://fjkraan.home.xs4all.nl/mechanics/zuseGates/
    30,992
    Your mention of a mechanical memory brought to mind a device that was developed around the WWII era. It was a typewriter-to-morse-code machine, but with a memory--that is, one could type ahead of the code being sent. Each keystroke set a pawl on a rotating drum, which pawl positions would be read while sending. I don't recall what the thing was called, but I'm sure there's a patent out there somewhere. This probably was an early implementation of keyboard buffering.
    Of course, read-write mechanical memory is very old. Consider the adjustable combination stops on a pipe organ.
    I don't think Zuse ever did get his mechanical memory to work well. I do like his relay based carry mechanism. It was much faster than a relay based carry that depended on the actuation of each bit's relay to pass the carry.
    The mechanical memory worked well enough to use it in the relay based Z4. It were the mechanical logic gates that weren't reliable. The Z2, Z3 and Z4 used relay based logic gates.
    Feb 2011
    2,082
    10
    Quote Originally Posted by fjkraan View Post
    It appears from Wikipedia that the Z series machines could not perform conditional branches, and so had to evaluate all possible outcomes of a problem. I believe that the essence of being a "Turing Complete Computer" is that you don't have to evaluate all possible outcomes. However Zuse was most certainly a pioneer in Computing
    I wonder how reliable this would be in practice. The first "electronic" computer was probably the ENIAC which ran a program from ROM (banks of switches) in April 1948. Operating ENIAC in "stored program" mode slowed its operation considerably, but increase the speed with which it could be programmed. The Manchester Baby was, as far as we know the first computer to run a program from "RAM" in July 1948. However this machine was not a true "digital" computer as it uses analogue techniques in many places, including the "subtractor". However the "williams tube" memory was licenced by IBM and used in the IBM701...
    Creating sufficient memory was a real problem for the early computing pioneers. All sorts of devices were used, and it wasn't until 1953 when core memory became available that compact reliable RAM was available.
    G4UGM
    The change from things like analog adders and subtractors mixed in with digital machines didn't go away until the cost of using diodes with transistors instead of resistors with tubes became cheaper. With tubes it was easier to make an AND function with two resistors creating a sum that was greater than the threshold of a tube ( an analog function ). It was all about minimizing the number of tubes.
    30,992
    Well, yes and no. One of the problems with tubes was reliability (ask any of the old SAGE people). Transistors were initially suspect, so a lot of diodes were used instead (e.g. PB250)--and alternate technologies stepped in to fill the gap. Parametrons (NEC systems) and core logic (Univac Solid State) were considered state-of-the-art at one time because their extreme reliability.
    The big advantages that silicon transistors had over tubes that really closed the books was speed, space and consistency in manufacture. When that materialized, the alternate technologies were dropped.
    I used to have some old logic boards with the little wire-leaded "peanut" tubes on them. PCB in the middle, with aluminum "wings" on either side. 6 tubes; 3 on each side, held in clips; every board that I bought had double triodes for all the tubes. They were very cheap on the surplus market; I was told that the only cost-effective way to troubleshoot these was to replace the whole assembly. I used several of the little triodes in some high-frequency experimentation.
    The Russians used tubes on their Venus lander so they can't be all that bad ( just kidding ). The NASA guys have been talking about making a lander using silicon carbide transistors for a Venus lander.
    I can't imagine using a tube computer for anything other than op-amps. Still, towards the end of tubes, they were making tubes that were really quite reliable. The smaller ones were capable of high frequencies as well. Filament power per compute was still an issue. They have been talking about making vacuum tubes with carbon nano tubes as cathodes. The idea is to use no heaters, just the strength of the fields will create free electrons.
    2,568
    I also recollect Russia using valves/tubes on some of their fighter planes - EMP resiliant?
    30,992
    RCA did introduce the idea of a "dark cathode" back in the 60s, but I don't know what became of the idea. Similarly, "tunnel cathodes" have been proposed, but in general, innovations on general-purpose tube types has been at a standstill for decades--and is likely to remain so. One friend who worked with SAGE said that the racks of tubes was a convenient place to leave your lunch to warm. Although high-frequency specialized tubes such as magnetrons, TWTs and klystrons are still used, the big enemy is the space between electrodes when it comes to making high-speed digital electronics.
