Results 1 to 10 of 16
Thread: Connecting logic outputs in parallel
    Sep 2012
    Kent, England
    152
    Default Connecting logic outputs in parallel
    In my Honeywell 200 replica project I have a problem that might need my design to sail close to the wind. I am using original Honeywell logic ICs from the 1960s that are probably DTL and the maximum fanout of the outputs is ten standard inputs. However, my design often requires a signal to go to sixteen input gates. I could double up on the output gates to provide for twenty input loads in total, but that would require using extra pins on the PCB edge connectors and there are never enough of them to do this. The question is whether I could connect two outputs to a single logic line to avoid needing an extra pin. It normally isn't advisable to connect transistors in parallel in this way unless they are thermally closely connected and otherwise similar, but my ICs each contain two similar gates on one chip, so maybe they do meet those requirements. Certainly the output pins on the ICs are close together, which suggests that the output transistors are too on the chips, so thermally very closely connected. If I connect all the corresponding inputs to the two similar gates in parallel as well then the IC ought to behave as one gate with twice the fanout ... maybe.
    The signals are at conventional five volt logic levels, so maybe a precaution would be to include a small resistor at each output to help balance the current evenly without the voltage lost causing too much detriment to the noise immunity. Also perhaps testing the outputs at full current capacity to determine whether they are closely matched in particular ICs would be a good precaution as there could be manufacturing differences even between transistors on the same chip. If the voltage differences between the two outputs with the same current at any temperature are negligible then the currents are likely to stay balanced at all temperatures, I assume, but maybe a long soak test at full load would be needed to check this.
    Another option that I have is to build output driver circuits using more powerful discrete transistors, but that would probably increase the propagation delays for the signals unless I build the entire DTL logic gates using discrete components, which would take up much more space on the PCBs. The original Honeywell 200 did use discrete components throughout, not these ICs which were introduced in another model, the 120, a few years later in the decade, but the H200 used twice as many backplanes as I have, so I need to put as much logic as I can on each PCB to save space. I'm keeping to Honeywell's convention for the number of ICs per PCB though, so I'm not crowding them, but the pin limited edge connectors were designed for use with far fewer logic gates per PCB constructed with discrete components, so those legacy edge connectors are always bottlenecks in my design.
    Does any experienced circuit engineer have an opinion on this?
    Rob - http://www.honeypi.org.uk
    The Internet is a winch to get your project off the ground ... but always have a parachute handy.
    34,387
    DTL didn't use active pullups, so you're safe in paralleling outputs; as a matter of fact, it was common practice to "wire OR" outputs on DTL and RTL--something forgotten since TTL days because almost all TTL uses totem-pole (push-pull) output.
    However, I'd probably look for a DTL "power gate", such as the 844 or 857, which have fanouts in excess of 25 loads.
    Sep 2012
    Kent, England
    152
    Chuck: Thanks for your remarks, but they aren't really applicable to my situation.
    For my machine to be regarded as being in the style of the 1960s Honeywell 200 range, even if it is only a pastiche, I am restricting myself as far as is practical to using components that I know Honeywell used during that decade in their machines. For that reason I am only using their own ICs and transistors from that decade. As a demonstration of my pedantry, I know that they started using AGNA1 monostable timer ICs (equivalent to the 9601) in place of timers constructed from discrete components some time around the end of the 1960s or start of the 1970s, but I need to confirm the precise design dates for the specific logic modules involved before I commit to using those ICs in my design. I have no evidence that Honeywell used IC power gates as drivers. They appear to have resorted to discrete transistor circuits wherever higher fanout was needed.
    I suspect that the design of the Honeywell ICs closely followed the design of their previous circuits built with discrete components but I don't have the internal schematics for the ICs to verify this. I have schematics for some of the discrete circuits and a striking thing about the later ICs is that they employ external feedback capacitors to regulate the rise time of the outputs in exactly the same way that the transistor output stages did. There are specific feedback pins for this purpose apart from the normal inputs.
    My tests on the ICs indicate that their outputs have a strong pull-up capability, probably active rather than resistive. Looking at the evolution of the equivalent discrete component modules, series three used pullup resistors in the output stages but the later series five used totem pole transistor stages. I referred to the ICs as probably being DTL because in the discrete circuits the inputs always used diodes rather than directly going to transistors, but I don't know what they are really. Certainly their outputs are powerful enough to be used as modest current sources, not just sinks, which I have actually done in some temporary test rigs, so it's highly unlikely that they can be wire or'd. In fact the range includes specific ICs that do provide wired or output and input connections for building large custom gates, but these can only be used together and not connected to the standard inputs and outputs. The normal ICs obviously have two transistor stages in them to eliminate inversion of the signals and the wired or connections appear to be special links to points between these as they are inversions of the normal logic.
    Hence my question was actually about the wisdom of paralleling totem pole outputs, which can only succeed if the two similar gates on the chip behave in exactly the same way with exactly the same responses to the paralleled inputs. It didn't occur to me that DTL is always assumed to have single ended outputs rather than totem poles, so I may have been misleading there. I thought that was only a characteristic of RTL.
    Working with these Honeywell ICs I've had to disregard my assumptions about mainstream IC development as they are unique in my experience with their special feedback and wired or connection points. The only thing that I can be sure of is that they have transistors in them somewhere that behave normally.
    Totem pole outputs are essentially constant current sources. I see no issue with paralleling them if they have the same input signal and use the same package. When pulling down, it is more of an issue for balance but with both on the same silicon it should work. My rule that has worked well in the past for both ICs and connectors in parallel is to multiply the individual current by 2 and then by the square root of two. Using 16 is a little on the outside of that rule that would say 14 is a safer number of loads to share. Of course small resistance will help sharing more.
    I was looking at connectors in parallel for power supplies. We saw connectors fail in parallel when exceeding this and working well when less then. It was based on a lot of connectors and measuring currents with a hall meter. The rule seems to work well for more connections, like 3 connector total divided by square root of 3. Why it worked I don't know as it was by experiment with connects af 50 to 100 amps.
    34,387
    Do you have any databooks on the Honeywell ICs of the time? That might help.
    Feb 2006
    in the basement
    889
    Quote Originally Posted by RobS View Post
    .....a striking thing about the later ICs is that
    specific feedback pins for this purpose apart from the normal inputs...
    Rob....Would you please explain the significance of the rise time..?
    Thank you
    ziloo
    Thank you
    ziloo
    Fast rise and fall times cause reflections of unterminated lines, power supply noise and possible cross talk.
    34,387
    I still don't quite understand why a power gate or buffer won't be used to accomplish the end. All logic families have them.
    Feb 2006
    in the basement
    889
    How about "level sensitive" and "edge sensitive".......... do these also apply to
    computer designs with discrete components?
    ziloo
    34,387
    Depends on the implementation. But yes, there were several implementations using capacitive coupling, which is essentially, "edge sensitive" logic.
    Details on the logic family being used are important.
    Bipolar TTL is current-driven with what amounts to "negative" logic--circuit drive capacity is stated as the ability to "sink" current, not to source it. CMOS is voltage-driven, so while fan-in current is tiny, voltage levels must be observed with attention to capacitive loading. Vacuum-tube logic essentially follows CMOS. There are many variations--and many all-but-forgotten logic families. ECL is probably still used in a few applications; RTL, HTL, DTL, DCTL, etc. are probably hard to come by.
