Results 1 to 9 of 9
Thread: FS: High End Gaming PC
    Sep 2017
    Porter County, Indiana, USA
    146
    Default FS: High End Gaming PC
    Specs
    i5 3570K
    16GB RAM
    GeForce 1050
    1TB HDD
    Blu-Ray Burner
    Looking for $400
    Mar 2009
    Dublin, CA USA
    2,897
    I am not sure I'd call that high end, though the price is reasonable for those specs IMO. Which generation is the i5? What motherboard? Does it come with a fully up to date OS (allright, that was a dig meant as a joke...).
    Do you have any pictures of it to share?
    Apr 2018
    Los Angeles, CA
    920
    Hey, this is a vintage forum, high end is relative... It's more high end then my main PC.
    Windows 10 or Windows 7, because.. ya know... Also, hopefully it doesn't have some of that Ransomware on it! I kid...
    I have nothing to contribute but it seems like a decent price for those specs.
    -- Brian
    A 3570K is Ivy Bridge
    I'm not sure I'd call it a gaming PC with a GTX 1050 in it -- the card that is basically GTX in name only -- "high end".
    Though that really depends on WHICH 1050. Hopefully it's one of the ones with GDDR instead of the cheap one with just plain DDR that performs worse than a GTS 8400 from a decade ago. At least the GDDR4 version is on par with a GTX 770.
    CUTCODEDOWN.COM
    1,917
    Quote Originally Posted by deathshadow View Post
    The only Geforce 10 series card that has a DDR4 version is the GT1030.
    There are two models of the 1050, the older 2 GB model and the newer 3 GB model. Both use GDDR5, but both have significant differences in their specs.
    The core config of the 2 GB model is 640:40:32, vs the 3 GB as 768:48:32. The 3 GB model has a smaller L2 cache of 768k (vs 1 MB of the 2 GB) and a slightly higher core clock of 1392 vs 1354 MHz of the 2 GB model.
    The biggest and most important difference is the memory bus width. The 2 GB version has a 128 bit bus, while the 3 GB only has a 96 bit memory bus, which results in a 25% bandwidth loss. What would otherwise be a much better card is crippled by the bandwidth constriction. This causes a mixed bag in terms of performance because games that rely heavily on memory bandwidth will perform worse on the 3 GB card, while games that prefer more memory will run better on the 3 GB card.
    In any case, this machine is at best a lower midrange gaming PC, nowhere near high-end. The pricing is in the realm of acceptable, but the full sysem specs need to be revealed to make that determination. The manufacturer of every part should be revealed, along with the model numbers.
    Sep 2017
    146
    I built what I could afford at the time. The processor was $25 the board was free and everything else bought on credit cards
    34,078
    I envy you--most of what I have are low- to middle-end gamey PCs...
    Jan 2014
    Western North Carolina, USA
    1,329
    An i5-3570k is not high end, but midrange. My laptop's i7-3740qm is higher end than that.
    EDIT: My laptop is a Dell Precision M6700 with 24GB, 500GB mSATA SSD, two 1TB HGST 7200 RPM HD's, 17 inch screen, and nvidia Quadro high midrange video, K5000m.
