Results 1 to 10 of 69
Thread: VAX 7000-640 CPU frequency
    Default VAX 7000-640 CPU frequency
    Living Computer museum grants access to VAX 7000-640 under OpenVMS - https://livingcomputers.org/Discover...em-Status.aspx. Is it possible to get its CPU frequency? The command show cpu doesn't show it. I'm ready to use assembly to get it. I know that the default frequency is 90.91 MHz but I have doubt about this particular system, it may be upgraded. Any help? Thanks.
    May 2018
    Lancashire
    574
    16
    SHO CPU / FULL doesnt show the CPU frequency and I dont think its available from a VAX chip.
    Seems ironic that its a live, in service, doing its job, working VAX 4000-705A I just tried that command on
    Quote Originally Posted by Gary C View Post
    Why VAX 4000-705A? I've just got the next text.
    $ show cpu /full
    ROSIE, a VAX 7000-640
    Multiprocessing is ENABLED. Streamlined synchronization image loaded.
    PRIMARY CPU = 00
    CPU 00 is in RUN state
    Current Process: *** None ***
    CPU revision level = 0.
    Capabilities of this CPU:
    PRIMARY QUORUM RUN
    Processes which can only execute on this CPU:
    CONFIGURE PID = 20200107 Reason: PRIMARY Capability
    CPU 01 is in RUN state
    Current Process: VOL PID = 20205F6E
    CPU revision level = 1.
    QUORUM RUN
    *** None ***
    CPU 02 is in RUN state
    CPU revision level = 2.
    QUORUM RUN
    *** None ***
    CPU 03 is in RUN state
    CPU revision level = 3.
    QUORUM RUN
    *** None ***
    Is it really impossible to get CPU frequency? I am gathering data for my project. IMHO the NVAX+ in this computer works faster than at 90.91 MHz.
    May 2018
    Lancashire
    574
    16
    Quote Originally Posted by vol.litwr View Post
    Why VAX 4000-705A? .
    Why ?, Its the box im logged onto as part of the user cluster (we still use DEC equipment in our live online database system, and thats the modern stuff, you should see our Honeywell DPS6 systems
    I dont think the VAX chip has any ID byte in it to pull the data from
    If I do the sho CPU command, I get
    $ sho cpu /full
    EC3B, a VAX 4000-705A
    Multiprocessing is DISABLED. Uniprocessing synchronization image loaded.
    PRIMARY CPU = 00
    Current Process: _TNA8425: PID = 2023C6C6
    PRIMARY QUORUM RUN
    Jul 2014
    Rhode Island
    1,346
    I worked on a DPS8 system running GCOS for a few years. It had two DPS6 systems for front-end processors, and DPS6 systems for RJE.
    DPS6 systems are still being used to monitor nuclear power plants in the UK.
    May 2018
    Lancashire
    574
    16
    Yep, I know
    Go on, ask me how I know
    Liverpool, England
    392
    Yep, I know
    You work for EDF?
    May 2018
    Lancashire
    574
    16
    Quote Originally Posted by PG31 View Post
    You work for EDF?
    Yep
    Spent about 10 years in the computer group working on the DPS6's and the UCS3600 control micros. Mainly hardware on the Honeywells and software on the Intel machines. We use CUTLASS which is actually a very good control language on the 80286 machines.
    The DPS6's are amazingly reliable. Been running for 31 years without missing a serious beat. Never lost any generation due to a computer fault.
    We have a VAX cluster that used to work on 11/750's and MicroVAX, but is mainly Alpha machines now and acts as an online datalogger.
    Liverpool, England
    392
    A major UK bank still ran RSX-11 on a PDP-11/53 until very recently. I now have that machine in my collection. They also had an 11/750 but I don't know what happened to it. Scrapped I suspect.
    Any other companies still running DEC PDP now or until very recently? I suspect a few machine shops still run with PDP-8???
    Feb 2011
    2,460
    10
    I don't think there are many eights out there. Until recently lots of machine shops had 11's but they are going. Lots of places moving to CNC lasers.
    G4UGM
