Page 2 of 7 FirstFirst 123456 ... LastLast
Results 11 to 20 of 64
Thread: Arduino keyboard emulator host wiring.
    Oh awesome, it auto-resized it for me. No matter, http://binarydinosaurs.co.uk/tandataPASchematics-01.jpg
    That one is zoomable.
    www.binarydinosaurs.co.uk - UK home computer history
    Where RIFA capacitors come to die
    facebook.com/binarydinosaurs
    31,289
    Woof--that is one involved keyboard scanning circuit. Do we have a datasheet on Z2? (5089--it seems).
    Not good. It is a touch tone signal. I thought it was just a regular keyboard. I assume from the pinouts that the two chips connected to the keyboard are 4051s? Z2 is a little more complicated than a regular cross matrix. What is Z2??
    Hi Chuck
    I was typing while you were posting. It looks like the pinout matches the 5089. Jameco has a pdf for it. I'm looking is it right now. There is a signal on Z5 pin 1 that I don't yet understand. Maybe the pdf will explain.
    TCM5089ANS Tone encoder, powered by telephones!
    https://www.datasheetarchive.com/pdf...M&term=TCM5089
    This PA is an autodialling hands free telephone too so that kinda makes sense.
    I should include the link to my writeup on the whole machine - http://binarydinosaurs.co.uk/Museum/Tandata, some interesting reading in there!
    31,289
    It seems that the 5089 isn't really part of the keyboard decoding per se, as the only output seems to be the DTMF tone for dialing.
    There's a connector to the left of Z6 that I'm having trouble figuring out.
    I think we need to see the keyboard. It my look like a regular matrix but actually the keys are normally like a double pole switch with a common ground. In other words there are two separate contacts being made, not just two lines connected together.
    Pics here: http://www.binarydinosaurs.co.uk/Museum/Tandata/pa.php
    It's a rubber dome keyboard, the keys really are two lines connected together as you can see from my little cursor key keyboard I made.
    Chuck, the connector to the left of Z6 looks to be the keyboard connector SK6. I've done a pic showing both sides of the board, two ticks while I upload.
