Results 1 to 2 of 2
Thread: T1100 screen assembly
    Default T1100 screen assembly
    Hey all,
    Does anyone have images of the internals of a T1100 display?
    There is an earth contact attached to the LCD ribbon and im unsure where it should be mounted. (the machine has been disassembled for years)
    Thanks
    6,167
    Welcome to these forums.
    Although I own a couple of Toshiba T1100's (not the T1100 PLUS), I am not willing to remove the seals that hide the screws that need to be removed.
    However, the following drawing is from the T1100 Technical Reference (at [here]), and that drawing roughly shows the attachment point.
