Page 1 of 3 123 LastLast
Results 1 to 10 of 25
Thread: New toys
    May 2018
    Lancashire
    128
    Default New toys
    Going to need a bigger garage !
    Just got permission to grab a MicroVAX 3100 and a VAXstation 4000-60 from work that I found in a locked room deep in the plant
    Just wish I had got the old computer bug before the pdp 11/73 was smashed up in the skip (though the 11/750 would probably been a bit too much)
    Jun 2012
    UK - Worcester
    2,558
    I've still got 73s down here that may be on the disposals list shortly...
    Send me a mail at work...
    May 2018
    Lancashire
    128
    Quote Originally Posted by daver2 View Post
    , will do
    Nifty What model is the MicroVAX? Those can be fun to play around with, though I heartily recommend enabling Telnet on whatever OS you end up running on it (mine's got NetBSD something-something at present) so you can avoid having to use the console port for anything more than initial boot; 9600 bps is usable for basic command-line stuff, but even text-heavy console applications starts to feel kinda sluggish (to say nothing of curses-based stuff.)
    Computers: Amiga 1200, DEC VAXStation 4000/60, DEC MicroPDP-11/73
    Synthesizers: Roland JX-10/SH-09/MT-32/D-50, Yamaha DX7-II/V50/TX7/TG33/FB-01, Korg MS-20 Mini/ARP Odyssey/DW-8000/X5DR, Ensoniq SQ-80, E-mu Proteus/2, Moog Satellite, Oberheim SEM
    "'Legacy code' often differs from its suggested alternative by actually working and scaling." - Bjarne Stroustrup
    May 2018
    Lancashire
    128
    Quote Originally Posted by commodorejohn View Post
    Its a microVAX-3100 model 20 with a TZ30. the VAX 4000 is a model 60
    Probably want to use a VT340 emulation, As I recall they were serial and plugged into a DECNET terminal server. Wonder if the emulator could skip the serial bit and work off of ethernet direct. What am I saying, of course it can, I use WRQ Reflections VT emulator every day at work ! lol. I would have to connect via the thin ethernet and ensure its running TCP/IP which Im sure it will as the system was setup to use this in the early 90's
    Been many a year since i have had anything to do with LAT or DECNET or VMS, not sure what it will boot up into though I think it has VMS on it.
    Mar 2004
    Wilmette, IL (north of Chicago)
    638
    I've probably got a 10base2 card around somewhere; pretty sure it would be ISA. Are you in US or UK?
    May 2018
    Lancashire
    128
    Uk, but I have found one for 10 with free shipping
    Mar 2004
    638
    Good news - it would probably cost at least that to ship it from here.
  9. #9
    Jan 2014
    Fort Worth, TX
    22
    Wish I was on that side of the big pond... On the other hand I just bought a nice 11/53 so I should be satisfied for a while, right?
  10. #10
    May 2018
    Lancashire
    128
    Quote Originally Posted by reinhardtjh View Post
    Is a collector ever satisifed ?
