Results 1 to 3 of 3
Thread: PDP-8 OS/8 file system questions
    Default PDP-8 OS/8 file system questions
    I've wondered about the type of file system that is supported with OS/8. I've done some searching and can't find much except that a file is stored in a single extent. Does that mean that blocks of a device are read and each block has some sort of header on it with the filename and how many blocks it takes up, etc.
    Aug 2010
    Silicon Valley USA
    771
    4
    Quote Originally Posted by alank2 View Post
    The OS8 Software Support Manual on bitsavers: http://www.bitsavers.org/pdf/dec/pdp...OS8_v3ssup.pdf Appendix A tells all.
    Thanks!
