Thread: Anti-static foam
    Sep 2006
    Silicon Valley
    1,814
    Default Anti-static foam
    There has been a twitter discussion about black anti-static foam eating IC leads.
    https://twitter.com/TubeTimeUS/statu...25948057382912
    short summary is it is the same "crumbly foam" failure mode of air filters made of polyurethane foam
    the hydrolysis through exposure to humidity releases acids which attack the IC leads
    Conductive Crosslink Polyethylene Foam doesn't have this problem
    http://www.correctproducts.com/ESD-P...link-Foam.html
    30,985
    I gave up foam quite some time ago. It's mostly tubes for me now.
    Is the pink closed-cell foam actually ESD safe? That stuff seems like it shouldn't degrade either, but I'm not sure of its conductivity.
    I'm slowly but surely working on converting to tubes as well.
    Sep 2006
    Silicon Valley
    1,814
    Quote Originally Posted by antiquekid3 View Post
    https://protektivepak.wordpress.com/...r-application/
    There are two broad classes of ESD foam, conductive (black) and dissipative (pink), and two base plastics, polyurethane and cross-linked polyethylene
    The problem is polyurethane breaks down when exposed to humidity, while cross-linked polyethylene
    does not.
    What I didn't know was there is a conductive cross-linked polyethylene foam, which is what I pointed to.
    Unfortunately, it may cost a lot more.
    This is the pink closed-cell foam I was thinking of: https://www.westfloridacomponents.co...ic+Charge.html
    I'm not sure what it's made of, but it seems like it'll have a hard time degrading like the polyurethane stuff does. At least from that one website, the stuff seems relatively cheap.
