Results 1 to 6 of 6
Thread: Spacers for model 1 units
    Mar 2016
    Pikesville, Maryland
    156
    Default Spacers for model 1 units
    OK
    I know there must be someone out there with a 3D printer and software who can produce the part shown in the photo. This is a plastic spacer used in the Model 1 units to keep the 2 motherboards "separated" from each other and prevent any shorting.
    Anyone willing to take on this challenge (I'd be willing to invest into the manufacture of this part). Would like to have them available for sale for the upcoming TA convention in September.
    Thanks in advance.
    Dimensions
    OD = 0.5 inch (1/2 inch)
    ID = 0.38 inch (6/16 inch)
    LENGTH = 0.44 inch (7/16 inch)
    Jay, isin’t this is just a common plastic spacer which should be readily available?
    Mar 2016
    156
    Well - I just learned that Home Depot and/or Lowes may have spacers close to this -- will check it out
    Jun 2015
    Sioux Falls SD
    222
    I bought plastic tubing and cut spacers
    Mar 2016
    156
    Never thought about that - thanks !!!!
    May 2013
    Williamstown Victoria Australia
    401
    Or even Garden hose cut in pieces ?
    Ray
    If it ain't Broke then PLEASE DONT fix it.
    Procrastinators Unite.
    I keep telling you I am Not Pedantic.
