Thread: Monitor for HP 9000/300
    Default Monitor for HP 9000/300
    I recently acquired an HP 9000/300 system from a computer store that was giving away old equipment, along with a HP 7937 disk drive, DEC Vaxstation II/GPX, SGI O2, IBM 5085, and some other accessories.
    The HP 9000/300 has the monochrome graphics adapter installed (98544B). It has a single RCA connector on it, and I tried plugging it into a composite monitor, but it didn't appear to be a normal resolution signal. What kind of monitor would I need to be able to connect to this computer? I have a keyboard and mouse, just no monitor.
    Sep 2006
    Silicon Valley
    1,817
    Feb 2006
    Jacksonville, Florida
    1,239
    Look at the collector's notes. The NEC LCD monitors listed can still be found on fleabay, They work with a lot of odd video formats.
    Feb 2006
    1,239
    BTW,
    If you are looking for one to buy, make sure is is one of the models listed on the HPmuseum website with BNC connections. The models that only have VGA connectors won't work.
    https://www.ebay.com/itm/NEC-MultiSy...torefresh=true
    Thanks for the tips! My VGA monitor actually supports sync-on-green, so I got a VGA to RGBHV (5 BNC connectors) adapter and plugged it up, and it works! However, the HP 7937 drive is having issues, so I can't boot it.
