Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Clogged dehumidifier
    Feb 2015
    Québec, Canada
    289
    I cleaned the dehumidifier with a hose nozzle on the vertical setting. It doesn't work very good, keeps freezing up. The room temperature is 20℃ so it should work, right. Maybe the de-icer does not work properly anymore but I don't think it should be freezing up in the first place. Does anyone know what causes that? It's from 1993. I never see any old dehumidifiers in people's homes so maybe they have really short lifespans? Did one or many of the solder joints break which leaked some of the refrigerant? I know nothing about these things so please help.
    Jan 2012
    Connecticut, USA
    2,397
    My dehumidifier I bought on amazon (Frigidaire) doesn't work/collect water when the temp gets down to 8 or 9 celcius. Frigidaire refunded me for the whole machine sans shipping so I use it in the summertime in my garage.
    If yours is icing up I suspect there is still dirt and dust inside which is collecting moisture. I would take the unit apart and see if you could spray water (not high pressure but maybe tap water pressure) to clean out the dust and debris.
    Other symptom would be low refrigerant which would mean a leak.
    5,891
    44
    I have used a pressure washer in the past to clean out plugged condensers and evaporators and unless you are blasting at hard angles to the fins or not using a con/fan tip they should not really bend or fold unless they are really badly corroded. For nicotine however you should really try the foaming fin cleaners. Most are designed to break down and dissolve debris and are pretty nasty if you get on your skin or clothes but works really well.
    Jan 2005
    1,573
    What about oven cleaner? Too harsh lol?
    Fantastic will actually remove some yellowing from plastics. But that's actually the real dark orangey brownish variety.
    5,891
    44
    Oven cleaner would probably work but I have no idea how it reacts to aluminum or copper or paints that are not baked enamel.
    There is a such thing as a/c coil cleaner. There is even a foaming version that you can use for automobile evaporators that you don’t want to remove the dash to clean.
    5,891
    44
    That's what I was referring to. IT foams up and is harsh enough that it lifts and forces most junk out from between the fins.
    Yep, sorry I missed that part. When I was skimming the thread I saw where you mentioned pressure washer and then I lazily stopped reading. That will teach me to be more thorough. Maybe.
    I remember at a college I worked at a maintenance guy had been kind of lazy changing a/c return filters up in the drop ceiling and left half of the fasteners out to make it easier. When a new guy got hired he was pretty angry because every single evaporator coil in the building was filthy. I saw him going around for a couple of weeks with a big sprayer of cleaner and some duct tape, cleaning coils and sealing up any leaks. I imagine that it saved the college a ton of money in electricity.
    33,370
    If it keeps freezing up after cleaning, suspect a refrigerant leak.
