Results 1 to 10 of 20
Thread: Packard Bell Legend "Operating System Not Found"
    Sep 2016
    Shrewsbury, MA
    1,307
    Default Packard Bell Legend "Operating System Not Found"
    Just got this old Packard Bell Legend for next to nothing and I'm trying to get it going with a new hard drive. The issue I'm having is it keeps telling me either "operating system not found" when I try to boot from a floppy. Currently I have everything but the floppy drive disconnected, I'm using a known good drive, and I've tried a new old stock copy of Windows 95, and 2 copies of 98se that I wrote fresh this morning. Any ideas?
    Have you tried a DOS boot disk?
    6,579
    BIOS settings for the hard drive parameters incorrect?
    How would that affect booting from a floppy?
    4,742
    What model Packard Bell? I mean Legend covers everything from a 286 to Pentiums some of which can't work with Win 9x.
    Mar 2009
    Dublin, CA USA
    2,920
    What type of floppy? 5.25 or 3.5? Also, what is the BIOS set to have for floppies, and does that match the drive you are using (older BIOSes default to 360kb 5.25")?
    In some cases, if the drive/BIOS expects a low density (360/720kb) drive and disk, but you are trying to boot from a HD disk, then you'd probably see this error as the system can't read the disk. So I would start by checking the BIOS settings. I would also try to boot my created boot disk in another machine just to verify it's not the problem.
    Jan 2012
    Connecticut, USA
    2,872
    So you have a known good floppy drive or hard drive connected? If its just the floppy drive make sure the hard drive (master and slave) are set to NONE. Does the system have a cmos battery? Any leakage? Have you tried replacing it?
    Sep 2016
    Shrewsbury, MA
    1,307
    I have a known good 1.44mb drive with the bios recognizing it as a 1.44, the ide devices are all set to none, it has a good cmos battery, and the specific model is Legend 2440, although I'm thinking it may have a later motherboard because it's a socket 5 Pentium 133
    Does the disk drive spin up? Does it seek? Do you have a known good floppy cable? With a twist?
    Sep 2016
    Shrewsbury, MA
    1,307
    Yes, yes, and yes. I've looked over it and I can't find anything wrong or even anything that could possibly be wrong
