Page 5 of 5 FirstFirst 12345
Results 41 to 50 of 50
Thread: Kaypro II - Yes! A telephone cable works fine for the keyboard!
  1. #41
    Apr 2018
    Los Angeles, CA
    860
    You could stuff both cables in the cubby of an SX-64 but you might damage something in the process and then where do you put your disks? You're out of luck anyway if it's a DX or you've added a drive to an SX.
    I've thought a lot about building a matching luggable case containing space for all this stuff plus a good size battery and inverter. ��
    I actually want to look into a way to mount a sd2iec adapter into the cubby of my sx-64, but i haven't thought of a nice way to do that which would be completely reversible. It would actually make that computer much more portable though.
    -- Brian
  2. #42
    ngtwolf, I just noticed that the setup on my table here is kind of reminiscent of your profile photo, minus the machines (a TRS-80 and an Apple IIgs?) on the left and right
    I've actually got a IIgs too, but it's not set up right now. Really would love to have one of those nice all-in-one TRS-80s someday!
    8-bit computers are awesome!
  3. #43
    Quote Originally Posted by ngtwolf View Post
    Why the cubby? If you want to use SD cards, do you need the 1541?
  4. #44
    Apr 2018
    Los Angeles, CA
    860
    Quote Originally Posted by compaqportableplus View Post
    Actually, my apple is a iie, no iigs, the one at the end is the PS/1. I would like to get a iigs at some point since i have all the stuff for one. Most everything I have is in my signature. Though, I'm not sure I have more space for anything more though, i already had to reorganize that setup when i got the Commodore PET.
    8-Bit machines are my primary interest though...
    -- Brian
  5. #45
    Apr 2018
    Los Angeles, CA
    860
    True, but I would like to keep everything that's there now, just add the sd option. I do still have disks so it'd be nice to have that option, whereas if i took over the cubby slot, it's nothing removed or anything I'd have to put back to undo my changes.
    -- Brian
  6. #46
    Yes, I know the one next to the Kaypro is a IIe, I just thought the one on the very left looked like a IIgs.
  7. #47
    Apr 2018
    Los Angeles, CA
    860
    Yeah, that's the PS/1... it's way too ugly to be a iigs. Its my ImageDisk (IMD) computer.
    -- Brian
  8. #48
    I don't know anything about this SD adaptor; does it allow you to put multiple disks on one card? If so, what I'm thinking is like the SD card in my wife's A2000: it's permanently mounted inside where nobody can see it. Otherwise, can it be fitted with a flat cable that would fit through the vents in the cubby?
  9. #49
    Apr 2018
    Los Angeles, CA
    860
    It's very similar to how a Gotek works, so you need buttons to switch between disks. While it has a menu system like the Amiga and Atari ST Gotek's use, it only really works for loading up the initial disk. You still need buttons to switch between disks (for multi-disk software). The Pi1541 would possibly even be a better option but it has even more buttons, i got some boards printed up where I can build out a few of those. I was thinking about running the wires through the vent holes, it'll just take some planning as i probably will want to make some 3d printed 'front', but at the moment its a low priority project. I'm still in the fixing computers stage and computers keep breaking as fast as I fix them (or too many unplanned acquisitions).
    -- Brian
  10. #50
    Its not the same. New cables use cheap thin wires wrapped around... String maybe and the resistance is way too high.. they don't work. I did alot of testing on my kaypros to figure this out. Old cables maybe 25+ years old or older with actual braided copper will work. Check the resistance first.
    May I ask what level of resistance of the cable are okay for Kaypros?
