Results 1 to 8 of 8
Thread: Does raid damage PCBs?
    Apr 2017
    N Bellmore, LI
    323
    Default Does raid damage PCBs?
    My Commodore Pet decided to get a Pet of its own and a spider made a small web between the logic board and analog board. I sprayed a small amount on the bottom side of the analog board and it crawled through the back vents of the pet where I got it good. I don't know if much went into the vents. I will be doing a recap of the analog board so it will get an IPA wash at some point but want to make sure I don't need to hurry to wash the board.
    Wanted: Any old clunky 286-P1 machine that has some kind of working battery or replaceable with off the shelf parts. Preferred: 10+lbs 386 machines.
    Wouldn't a vacuum cleaner have sufficed?
    I wouldn't trust any such chemical for this!
    Apr 2017
    N Bellmore, LI
    323
    Damn, why didn't I think of that. Took the back of the tube housing off, looks dry inside.
    Feb 2017
    Chilliwack, BC, Canada
    529
    I'm confused as to what the problem with the spider is that you'd need a can of Raid to deal with it. This isn't one of those Australian spiders so big it has a health bar, is it?
    My vintage systems: Tandy 1000 HX, Tandy 1000 RSX, Tandy 1100FD, Tandy 64K CoCo 2, Commodore VIC-20, and some random Pentium in a Hewitt Rand chassis...
    Apr 2017
    N Bellmore, LI
    323
    I've been having a few issues with bugs lately, mainly ones the size of Australian insects flying in. I get it, I shouldn't have used raid. The question was does raid damage boards, not did I overreact to an insect.
    33,661
    Probably not--what's in the can is mostly propellant and the remainder is largely nonreactive:
    SDS for Raid(tm) flying insect killer
    Oct 2016
    Cincinnati, Ohio USA
    436
    I just looked at the SDS and agree that it shouldn't hurt anything. It may leave a residue that could attract dust, your IPA wash should remove that.
    PCjr, DTK PC-XT Turbo, 386DX 33, 486 laptop, Pentium 120, Pentium III 500, various old laptops, Commodore Colt, all working. I also have a 286 that I need to see if I can repair.
    Apr 2017
    N Bellmore, LI
    323
    Quote Originally Posted by KenEG View Post
    This is what I mainly suspected but Thanks.
