Results 1 to 6 of 6
Thread: WTB / Need TRS-80 Model 1 Keycaps
    Default WTB / Need TRS-80 Model 1 Keycaps
    I've got this Radio Shack TRS-80 Model 1 working after replacing a chip in the Video RAM.
    I'm missing three key caps. 'X, ':' and 'BREAK'. Anyone have some spares? Is there a TRS-80 Bone yard?
    Wonder if a model 4 keyboard can be a Donner? The break key would be the wrong color though. I believe the model 4 break key is white where the model 1 is black.
    KF7CRU @jhalbrecht @TheRetroWagon Looking for Solid State Music SB1 please DM me.
    http://www.theretrowagon.com/vcf-west-2017/
    Jan 2011
    Portland, Oregon
    639
    Mar 2016
    Pikesville, Maryland
    193
    I sell them
    Attached is a photo showing the (2) types of keycaps for the Model 1.
    Can you remove a good keycap and take a photo so I can see which one you need
    I don't think you can use a Model 4 keyboard (check with Ian)
    If interested please contact me at my email address ======> JAYNEWIRTH@VERIZON.NET
    Default Parts ordered
    Quote Originally Posted by MikeModifed View Post
    I ordered up the three keys from Ian Mavric. Thanks for the link. $5/each plus $4 from Australia and $0.99 from PayPal I guess for currency conversion and funding.
    Ian says; "You can't use M4 key caps on this Model I. If you had a later Model I with the ALPS keyboard then you could use M4 key caps on it." Where M4 is the model 4 I asked about using as a donor.
    On twitter I learned;
    @abtnatural
    Replying to @theretrowagon
    Keys from a Model 4 won't work. Even keys from a later Model I won't work. It looks like both of your systems have the original TRS-80 keyboard, most easily identified by the 8-pointed asterisk (all later I/III/4 asterisks are 6-pointed).
    Another way to tell if its an ALPS, the @ will be smaller on the ALPS Model I vs the Cherry being bigger. Thats if you're looking at one online and cant pop it apart.
    Default Keys installed
    Quote Originally Posted by jhalbrecht View Post
    I received the keys and installed. Hooked it up with the expansion interface and the video monitor. Works!
    Placed an ad for it on CraigsList and updated and enhanced my wiki page a bit.
Tags for this Thread
