Page 1 of 4 1234 LastLast
Results 1 to 10 of 40
Thread: Using DOSEMU on 64-bit Linux issues
    34,532
    Default Using DOSEMU on 64-bit Linux issues
    For some time now, my DPMI-using DOS applications running under DOSEMU on AMD64 Linux terminate with the following message:
    DPMI: Unhandled Exception 0e - Terminating Client
    It is likely that dosemu is unstable now and should be rebooted
    This includes PKZIP as well as Microsoft MASM 6.13 and 16-bit C 8.00c. The same applications run fine under XP loaded in a Virtual Box session, but both VB and DOSEMU integrate poorly with the existing Linux environment.
    Does anyone know of a fix for this?
    (I believe that this qualifies as "vintage software", since there hasn't been a new version of 16-bit MS C in 20 years).
    I don't use DOSEMU (yet, looks interesting), but do you know what version you are using? I found this linked from WikiPedia: https://bugs.debian.org/cgi-bin/bugr...cgi?bug=751632
    Chuck, I don't have an answer for your question, however I suggest you to check here, if you already haven't:
    http://www.dosemu.org/docs/HOWTO/x503.html
    However, I find "recent" versions of Dosemu a nightmare with respect to (quite) old ones. For example I'm running a few vintage EPROM programmers from the '80s, including a HI-LO one that has a custom ISA board and a few DATA I/O connected via RS-232. I've found no way to make a simple serial port (real hardware one, not USB) under modern Dosemu versions work. I'm keeping an old 486DX PC running a 2002-ish version of Linux and Dosemu just for these programmers (and no, the HI-LO software would not run on real MS-DOS on a 486DX, it's failing to adapt to the actual clock speed).
    I whish at least the normal serial ports would be functioning on recent Dosemu versions so I could move the programmers on more modern PCs.
    I'm starting to think we should keep some old hardware running for the old software now..
    Frank
    What about DOSBOX? Does it work okay in that?
    Various projects and oddities: http://oldvcr.blogspot.com/
    34,532
    I'm using Dosemu 1.4.0.8, so the version hasn't changed much (1.4.0.8 dates from 2103). It seems that later "security" mods to the Linux kernel have gotten in the way of this, however and I'd like to know how to overcome them. Some switches in "/proc" perhaps?
    Note that Dosemu isn't like DOSBOX; it runs code natively and provides a more-or-less seamless mapping to Linux files--one can even run Linux commands in a Dosemu session, so my D: drive corresponds to my Linux /home directory.
    Here's my Dosemu logon:
    DOSEMU 1.4.0.8 (2013-01-05), configured: 2018-04-03 20:42:17 +0000
    Please test against a recent version before reporting bugs and problems.
    Submit Bugs & Patches to linux-msdos@vger.kernel.org or via http://dosemu.org.
    FreeDOS kernel 2040 (build 2040 OEM:0xfd) [compiled Jun 21 2011]
    Kernel compatibility 7.10 - WATCOMC - FAT32 support
    (C) Copyright 1995-2011 Pasquale J. Villani and The FreeDOS Project.
    All Rights Reserved. This is free software and comes with ABSOLUTELY NO
    WARRANTY; you can redistribute it and/or modify it under the terms of the
    GNU General Public License as published by the Free Software Foundation;
    either version 2, or (at your option) any later version.
    C: HD1, Pri[ 1], CHS=    0-1-1, start=     0 MB, size=   392 MB
    dosemu XMS 3.0 driver installed.
    dosemu EMS driver rev 0.5 installed.
    [dosemu cdrom driver installed (V0.2)]
    Kernel: allocated 46 Diskbuffers = 24472 Bytes in HMA
    FreeCom version 0.84-pre2 XMS_Swap [Aug 28 2006 00:29:00]
    HXLdr32 V1.12 installed. Win32 console apps may possibly run now in DOS
    Sound on: SB at 0x220-0x22f, IRQ=5, DMA8=1, DMA16=5. MPU-401 at 0x330-0x331.
    D: = LINUX\FS/HOME/CHUCK attrib = READ/WRITE
    E: = LINUX\FS\CDROM attrib = READ/WRITE
    "Welcome to dosemu 1.4.0.8!"
    C:\>
    Did you try:
    echo 1 > /proc/sys/abi/ldt16
    That tip should probably be part of the dosemu documentation.
    from the bug report?
    34,532
    Not possible any longer; seems that it's been removed from the kernel:
    root@Columbia:/proc/sys/abi# echo 1 >/proc/sys/abi/ldt16
    bash: /proc/sys/abi/ldt16: No such file or directory
    Are there any switches in /boot/config* that I should be looking at?
    So I dragged out my 64 bit linux laptop and installed DOSEMU. No dice running WATCOM tools. I then decided to try running under Wine and it came back with "unable to allocate DOS memory. Install DOSBox".
    Ouch.
    34,532
    The integration of Wine using DOSBox leaves--er, something to be desired. At that point, I go to VirtualBox and boot XP. I'll confess that I've not tried running ML or CL using DOSBOX under Wine.
    The problem for me using XP under VBox is an executable file on a shared Linux filesystem isn't executable--you have to copy it over to the local XP drive. Bit of a bother, there.
    Under the old DOSEMU, you used to be able to run PKZIP without any special switches, now you have to disable 32-bit mode (-3 option) explicitly.
    Why run DOSBOX under Wine? Why not just run it directly? I run it on this Linux POWER9.
    You can mount local paths as drive letters.
