Results 11 to 20 of 27
Thread: DOS DIR Command is super slow on a large drive
    34,376
    18
    True, but then you don't get file sizes, either--just the bare file names.
    Quote Originally Posted by Shadow Lord View Post
    That makes since.
    Should of course be sense.
    I thought this issue was due to the free space calculation, and that there was a way to turn it off.
    DIR /b will skip the free space calculation.
    Thanks guys. Yes that is what it was. It was pretty well discussed/known years back when HDD sizes started getting real big and people still had slower systems but now trying to find it on the web is impossible. It is like old MS KB articles. The purge of knowledge is almost complete.
    Quote Originally Posted by Krille View Post
    The problem is that DIR calculates the amount of free space on the drive by reading the file allocation table and adding up all clusters marked as free. The only solution is to reduce the size of the FAT, which means reduce the number of clusters on the drive. There are two ways to do this;
    I am having the same issue with 4DOS so I am guessing all the command processors do the calculation the same way.
    1. Increase the cluster size.
    2. Reduce the size of the partition so you're just over the power of 2 boundary.
    Thanks for the very informative reply. Looking at those solutions they both have down sides:
    1. Going to bigger cluster sizes = massive slack space waste (i.e. storing 2K DOS .com file in a 64K cluster)
    2. That would lead to partitioning the drive and multiple drive letters which is what I was trying to avoid in the first place.
    Although if I am understanding it correctly the problem should resolve itself as time goes on. That is, as the HDD fills up there are less free clusters to be added up so DIR gets faster.
    10 seconds sounds excessive. Make sure you have a sufficient number of BUFFERS in config.sys and/or that you have some disk cache like SmartDrive loaded. If the drive is formatted to use the minimum cluster size (1 sector per cluster) then that could also explain the slowness.
    I have my buffers set to minimum. My rudimentary understanding of buffers leads me to believe that they are unnecessary with a cache loaded. The one place I am not sure if buffers would help with is in the MS Client redirector. The setup program recommends increasing buffers (I think to 20). I am not sure if cache would also help in the case of MS Client or you actually need to allocate the buffers for better performance.
    Current Wish List: 1. IBM 7531 Industrial Series PC 2. NEC MultiSync XL (JC-2001) Monitor 3. MicroSolutions MatchPoint AND/OR UniDOS card 4. Compaq 14" VGA CRT Monitor (the one that came with the SystemPro). 5. Stacker HW CoProcessor Board MCA BUS. If you have any of the above for sale please PM me. Thank you!
    34,376
    18
    FAT32 has other interesting quirks under real-mode DOS. For example, I often discover that a newly-created file isn't listed the first time I do a DIR, but appears on the second one... It doesn't seem to hurt anything, but I keep this in mind.
    Easiest solution: Use drive and partition sizes that are appropriate to the age of the machine. A 2 GB partition on a 4.77 MHz PC or XT is ludicrous, since you'd never come close to filling it up even if you copied onto it every piece of software you ever wanted to run on it. Formatting a couple of 40 or 80 MB partitions and leaving the rest of the drive or card unused will still give you an amount of drive capacity that was considered enormous (and terribly expensive) when the machine was new, and will make counting up the free space much quicker.
  5. #15
    Mar 2012
    Augusta, Georgia, USA
    766
    I seem to recall a replacement dir command that fixed this issue, since it skipped the space calc.
  6. #16
    Me too. I wrote one. It still displayed file sizes, and even free space, but not by default.
    Heh history has forgotten this too; unless someone somewhere has the old Exec-PC BBS archives around somewhere...
  7. #17
    Quote Originally Posted by vwestlife View Post
    Yes but this is a 4GB drive on a 486-50. Its not like I have a 32GB CF card in there.
  8. #18
    Aug 2006
    Chicagoland, Illinois, USA
    6,546
    My advice: Make 2G partitions until you run out of space. Don't worry about slack. 10 seconds is easy (consider 17 seconds for a 5150, or 50 (!) seconds for a PCjr). Also, it only happens once -- build "DIR C:" into your AUTOEXEC.BAT if you don't want to ever wait on-demand.
    There was a utility created and shared on this forum (somewhere) that saved the free-space allocation calc to disk on demand, and could be restored on boot-up. The obvious downside is that if that ever gets out of sync, you will have problems. I don't personally recommend it.
    Offering a bounty for:
  9. #19
    Mar 2017
    New Jersey, USA
    574
    4GB seems big to me for a 486. The Compaq Deskpro 486/33M system commonly shipped with a 120MB drive, and the Deskpro 66M commonly had a 240MB drive. The later Compaq Deskpro XL line (which ranged from 486/66 to Pentium Pro) had storage ranging from 500MB to 2GB.
    I think the sweet spot for DOS is 500MB (assuming you're not running something so old you're limited to 32MB partitions). Beyond that the expectation would have been that you're running Windows 95 or later.
  10. #20
    Interesting. Would this feed the DIR command or would you need to run DIR once and then the utility would store the information in memory to disk for restore later? I like your idea of DIR in autoexec. One could run dir > nul and while getting coffee as the machine is booting.
