Results 1 to 8 of 8
Thread: Change owner name on Compaq Portable III?
    May 2018
    Washington state, USA
    13
    Default Change owner name on Compaq Portable III?
    We have a working Compaq Portable III we'd like to resell, but it displays the previous owner's name and phone number on the main menu.
    I assume the diagnostic disks have the tool to change that, but we don't have a functioning 360kb drive to create the disk.
    Is there a way to change the menu header from within DOS?
    It's running Compaq Personal Computer DOS Version 3.31
    Thank you.
    FWIW, I don't believe those diagnostic disks have the ability to edit what you have described. That would most likely be a feature of the menu program.
    3,226
    Exactly what menu program is it? If it is something that did not come from Compaq, then you might just change it to start to command.com and call it a day.
    May 2018
    13
    I had thought the menu was proprietary, but upon further investigation it's just 3DMenu.
    There are also a lot of documents on the hard drive, I believe it would be less time-consuming to simply reformat with a copy of Compaq's PC-DOS 3.31, but I don't see any images for their installer on 1.2MB 5.25" disks.
    Does anyone have an image I can use?
    5,947
    There's a 1.2MB image over at https://winworldpc.com/product/ms-dos/331 but it's OEM Emerson -- probably not what you want if you're trying to keep the machine stock. The solution in this case is to make the proper 3.5" image, boot it on a system that has 3.5" as drive A: and 5.25" as drive B:, then format the 1.2MB floppy using FORMAT B: /S so that the system gets transferred over, then copy the rest of the DOS files over normally. That will make a disk you can boot and install from.
    Quote Originally Posted by SBK View Post
    There are also a lot of documents on the hard drive, I believe it would be less time-consuming to simply reformat with a copy of Compaq's PC-DOS 3.31...
    Seems like time has already shown that is not the case.
    Just delete the files and move on.
    3,226
    You could probably use the 720k 3.5" disk images and use WinImage to resize them to 1.2mb.
    I have a copy of Compaq dos 3.3, is that close enough for your taste?
