Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: VT100 demo animation ideas
    Aug 2006
    Chicagoland, Illinois, USA
    5,730
    I'm sure, many moons ago, I saw the Star Wars animation playing just fine at 38400, which allows for two full-screen repaints per second. The delay numbers could certainly be scaled.
    Offering a bounty for:
    I imagine baud-rate concerns are one of the reasons the animation is only 68x13 (cinematic aspect ratio being another.) That's still 884 characters per frame, though.
    Definitely gonna take a stab at converting this to a more vintage-friendly transfer format.
    Computers: Amiga 1200, DEC VAXStation 4000/60, DEC MicroPDP-11/73
    Synthesizers: Roland JX-10/SH-09/MT-32/D-50, Yamaha DX7-II/V50/TX7/TG33/FB-01, Korg MS-20 Mini/ARP Odyssey/DW-8000/X5DR, Ensoniq SQ-80, E-mu Proteus/2, Moog Satellite, Oberheim SEM
    "'Legacy code' often differs from its suggested alternative by actually working and scaling." - Bjarne Stroustrup
    Mar 2006
    Salt Lake City, UT, USA
    193
    Simplest way to convert it might be to write a curses application that writes each frame into the window and then calls refresh.
    Curses already has logic to determine the minimum amount of work needed to refresh the screen from the updated internal data structure.
    Write the curses program to play back the uncompressed movie and just record the ESC sequences emitted by curses.
    That's simple, for sure, although IIRC curses re-paints on a per-line basis, so you could still probably compress it further if you wanted.
  5. #15
    Mar 2006
    193
    I did some hacking on my demo animation this weekend. It's coming along nicely. It's more of a demoscene kind of animation than it is like the Star Wars animation.
