Page 2 of 2 FirstFirst 12
Results 11 to 20 of 20
Thread: VT100 demo animation ideas
    6,540
    I'm sure, many moons ago, I saw the Star Wars animation playing just fine at 38400, which allows for two full-screen repaints per second. The delay numbers could certainly be scaled.
    I imagine baud-rate concerns are one of the reasons the animation is only 68x13 (cinematic aspect ratio being another.) That's still 884 characters per frame, though.
    Definitely gonna take a stab at converting this to a more vintage-friendly transfer format.
    Mar 2006
    Salt Lake City, UT, USA
    383
    Simplest way to convert it might be to write a curses application that writes each frame into the window and then calls refresh.
    Curses already has logic to determine the minimum amount of work needed to refresh the screen from the updated internal data structure.
    Write the curses program to play back the uncompressed movie and just record the ESC sequences emitted by curses.
    That's simple, for sure, although IIRC curses re-paints on a per-line basis, so you could still probably compress it further if you wanted.
    Mar 2006
    383
    I did some hacking on my demo animation this weekend. It's coming along nicely. It's more of a demoscene kind of animation than it is like the Star Wars animation.
    Mar 2006
    383
    Work is continuing on this demo. I'll release it for public consumption after VCFMW, but I don't want to steal thunder from the show .
    I've decided that the "demo" will not only showcase features of the VT100 and some "programmer art", but will also tell the story of the VT100 with heavy emphasis on internal design details.
    Mar 2006
    383
    Attribute wave effect added and optimized last night
    Mar 2006
    383
    I've uploaded some code that I wrote to help produce VT100 animation effects:
    https://github.com/LegalizeAdulthood/vteffect
    There are three utilities in this repository:
    • scat, "slow cat" program for playing animations at a specific baud rate
    • vtdump, dumps a VT100 animation as a sequence of commands
    • vteffect, generates a particular effect as a VT100 escape sequence
    I used this code and some hand editing to create an animation that I was displaying at VCF MidWest.
    Pull requests welcome
    Mar 2006
    383
    Added a fourth utility, vtasm, that is the inverse of vtdump. I'm still not recovering byte identical output by doing vtdump -> vtasm, so there are obviously some bugs left to still work out. It's very close, but not perfect.
    Mar 2006
    383
    OK, I have fixed the issue where vtasm didn't correctly reproduce the input to vtdump.
