Results 1 to 3 of 3
Thread: Laptops / Portables with ATA Interface - how can I know?
    Default Laptops / Portables with ATA Interface - how can I know?
    Hello!
    I am / will be looking to get my hands on something in the 386/486/early Pentium range of laptop/portables. I think my biggest concern is ensuring that the disk controller is ATA compatible, so I can run CF and not worry about the old mechanical drives breaking down on me.
    Is there documented anywhere, or does anyone have insight on, what I can expect to find? I assume all Pentium-era units would be ATA compatible, but is it safe to say all 486s are? I would imagine it gets fuzzier in the 386 laptop range, but is there maybe a list of units that are known to work well with what I want to do?
    My easiest route would be to buy a Pentium laptop (Compaq Armada series comes to mind, I had a beautiful 7710 once), but for some reason I'm looking to get something a little more...interesting, albeit not wanting to spend a ton (more than, say, $150).
    Thanks for any advice, and I apologize for my rambling question...it is the product of an uninformed mind.
    Outer Mongolia
    2,557
    You're probably fine with most laptops made after 1990 or so, outside of a few really proprietary/ultra compact machines, at least from an electrical/plug compatibility standpoint. Earlier than that, and particularly anything with an 8088/286 processor might be another story. (I recall some early Compaq LTEs used a Conner drive with a weird plug, and then there were those PrairieTek drives that I don't think were full according-to-Hoyle IDE...)
    486 laptops are almost certainly safe, again, unless it's something ultra-compact or otherwise strange. (Apple made some 68040 laptops that has 2.5" SCSI drives in them, I don't *know* if any PC manufacturer used them but I suppose it's a remote possibility.) I'm sure if you Google the name/model of any reasonably popular laptop that you might be considering you'll be able to unearth its specs.
    May 2016
    Fairfield, Ohio
    466
    The Compaq Portable 386 uses an ATA controller.
