Results 1 to 8 of 8
Thread: 486 random hangs/errors.
    Apr 2019
    Florida, United States
    16
    Default 486 random hangs/errors.
    Hello all.
    I recently acquired a rather clean looking 486 machine via everyone's favorite auction site.
    Everything seems to work normally until it doesn't.
    For example:
    Install windows 3.11 or 3.1 successfully, hangs on first boot after restart.
    Randomly says its out of memory when trying to run games you ran ten minutes ago.
    Random crashes when you get windows running, namely after trying to run something from a floppy disk or the hard disk. (installers, games that will run fine in dos, etc)
    The machines specs are as follows:
    Seanix 486VLP motherboard. (Unsure if Rev 1.1 or 2.0)
    Cyrix 486DX2-50 with write back cache
    12MB ram
    VIBRA16 sound card
    Cirrus Logic GD5420 video card
    And a floppy/ide controller card I am not sure of the model of.
    There is no L2 cache installed.
    Any help would be greatly appreciated.
    Mar 2009
    Dublin, CA USA
    2,920
    Start by testing the memory with the older version of Memtest86+ (download it, create a boot disk and boot it, then let it run for a few hours).
    Aug 2015
    Kansas City area, US
    66
    Heatsink and fan on the CPU? With a DX2/50 you should be able to get away with just a heat sink, but Cyrix tended to run hot.
    Apr 2019
    16
    Tried this as soon as I saw your reply (actually not sure how I didn't think of this, thank you!), but even Memtest86+ caused hangups, which made me check the memory physically. Seems one of the modules was toast, as the machine wouldn't work with just it installed, but works with the other module installed.
    So I'm down to 8MB of ram, but seeing proper stability now.
    Windows 3.1 loads and runs fine, and I'm considering upgrading it to 3.11 though I can't justify it yet.
    Quote Originally Posted by eswan View Post
    Definitely has a heatsink, and I just installed a small fan on it today because, yep, Cyrix chips do run pretty hot compared to Intel/AMD
    Considering putting a 5x86-100 in here and installing some cache and bigger RAM.
    Also was wondering if anybody knows anything about installing multiple floppy controllers to allow for more than two floppy drives.
    Thanks.
    6,700
    Quote Originally Posted by Galaxian View Post
    Note that controllers exist, such as the one shown at [here], that can have more than two drives attached.
    Apr 2019
    16
    Ah yes, the elusive (for me) kind of controller. Sadly I'll have to add a second controller. I'm only doing it so I can add a gotek. A lot of my old disks are beyond worn out.
    Jun 2019
    Vancouver WA
    23
    What clock is the motherboard set too? The intel dx50 was originally meant to run at 50mhz, but due to problems it was scaled back to a clock of 25mhz, I believe your Cyrex should be running at 25. Also you might want to check if your system was made for cyrex, if not you can find 486 cheap on eBay, I got a couple for around $20, dx2 66 and dx4100.
    Windows for Workgroups 3.11 supports network.
    As mentioned before, there are cards around that support four floppy drives.
    Then please have a look at https://github.com/skiselev/floppy_bios
    www.baltissen.org
