Results 1 to 3 of 3
Thread: TransEra 752-ADC Analog to Digital Converter ROM Pack for Tektronix 4052/4054
    Default TransEra 752-ADC Analog to Digital Converter ROM Pack for Tektronix 4052/4054
    I captured the EPROM and PAL files from my TransEra 752-ADC Analog to Digital Converter ROM Pack for the Tektronix 4052/4054.
    Here is the link to the RAR archive containing the Motorola S-Record file capture for the ROM for this ROM Pack (no PAL, the other socketed IC was a TI TTL to MOS level converter):
    Here is a photo of the back of that ROM Pack board with the cover of the ROM Pack - showing the ROM Calls:
    Here are a couple more photos showing the other side of the board and closeups:
    Here is the 752-ADC Command List:
    The manual I have has notes that TransEra modified the four A to D ROM Packs to allow all four to be used at the same time!
    I only have the one 16 bit A to D interface, but I imagine someone had 64 bits of A to D
    Here are the specifications:
    Last edited by nikola-wan; June 8th, 2019 at 02:50 PM. Reason: added specifications
