Page 3 of 3 FirstFirst 123
Results 21 to 28 of 28
Thread: PCB mounting suggestions
  1. #21
    34,518
    18
    Acrylic, not wood. I've got a pile of 3/8" stuff that should do the job.
  2. #22
    Apr 2011
    Brisbane, Australia
    544
    10
    There looks to be enough room on the short edges to trap them under the head of four 5/8" long nylon pan head screws, through a 1/4" standoff spacer tube between the board underside and the base plate, eg the acrylic as you have.
  3. #23
    34,518
    18
    Less edge there than you'd think; I'm not exaggerating when I say a half millimeter--even 4-40 pan head screws don't to a reliable job. But thanks anyway.
  4. #24
    I think that by what he means, you could even use a " screw, with 0.016" (less than half a millimetre) of PCB edge trapped under the head of a screw.
    But I think a card edge holder/card slot would be a better way to go. Or, simply a larger PCB to plug it onto, with holes exposing the connector, LED, and switches.
  5. #25
    Apr 2011
    Brisbane, Australia
    544
    10
    Yes that's pretty much it. For the card slot approach you could cut two strips of the acrylic then mill, dremel or even hacksaw a shallow card slot across the middle of them and superglue to the base piece with the board in place.
  6. #26
    Jan 2013
    Lake Havasu City, Arizona USA
    289
    I wonder if there is enough of an edge there where you could mount 2 of these style things and slide it between them to hold it.
  7. Default
    If you go visit a model shop or find your nearest pet railway/railroad or structure modeller you can get a ton of useful shapes (L, U, Hand other small sections) in plastic strip premade and extremely cheap. Look for Plastruct and Evergreen. Saves an awful lot of hassle cutting and shaping stuff and can be used to make nice board holders.
  8. #28
    34,518
    18
    Nice suggestion, but this is going to be a bit challenging for standard shapes. I've got a shop full of tools, so it should be pretty easy. I could machine card guides from nickel-silver if the mood struck me.
