Results 1 to 10 of 28
Thread: PCB mounting suggestions
    34,581
    Default PCB mounting suggestions
    For a retro computer implementation, I picked up one of these STM32F429 boards:
    From a technical standpoint, it's pretty decent. Lots of 5V tolerant I/O 180 MHz MCU. RTC with optional battery backup and 8MB of SRAM.
    My big problem is mounting the thing. Note that there are no mounting holes, nor anywhere to drill them, so you have to rely on the headers to hold the board in place. Okay, not so bad--I've got a bunch of dual-row female headers that will be perfect. But look at the 20-pin programming connector! If I insert the board into matching female headers, the programming connector is inaccessible! I'd have to remove the board, program it and then re-insert for testing. Why the designers didn't specify a right-angle connector is beyond my understanding.
    For comparison, consider this STM32F407 board;
    Near-perfect design--uses a mini-USB connector instead of a wimpy micro one. 4 mounting holes, everything on the top of the PCB, right down to the coin cell holder for the RTC.
    So, other than replacing the programming connector on the first one, does anyone have any suggestions for being able to mount the thing programming connector "up"?
    Sep 2003
    Ohio/USA
    8,025
    34,581
    Doesn't fix the problem. As I said, I've got dual-row female PCB headers, but that leaves the issue of the programming header as well as the pushbuttons and LEDs now being on the underside.
    Mar 2009
    Dublin, CA USA
    2,925
    Desolder the headers and flip them to the underside of the board? Or just use double sided tape, the 3m outdoor tape would be my choice.
    34,581
    I'm considering gluing a couple "ears" with mounting holes to the headers. Of course, the pin silk screen is on the bottom side...
    I'll keep you posted on what I decide.
    Mar 2009
    Dublin, CA USA
    2,925
    How about this: https://www.adafruit.com/product/1116
    Edge mount standoffs.
    Sep 2008
    SE MI
    4,796
    6
    What I've done in the past: Drill mounting holes in the PCB. Obtain standoffs and screws from Ace hardware. (the aisle with the slide out cases of nuts & bolts).
    So your only concern is the 20 pin connector? I'd plug a 20 pin IDC and ribbon cable into it and relocate it.
    34,581
    No--with the board upside-down, you can't get to the buttons or see the LED either.
    Light conducting plastic and a plastic crowbar.
