Page 2 of 2 FirstFirst 12
Results 11 to 17 of 17
Thread: Loaded Altair 8800 discovered yesterday with tons of paperwork & punch tape programs
    I tried a few mild cleaners... and a plastic scraper... this stuff is solid as a rock. Very disheartening. But thank you for the encouragement! Not sure what the plan is as of yet.
    Quote Originally Posted by aaron7 View Post
    You need to soak them. It takes time. It took year to dry out it'll take some time. Soak them with water and dish soap.
    I don't think it's a good idea to soak anything with circuitry in plain water. You could use deionized water to avoid charge-carrying minerals from building up on sensitive components. You'd still have to let it dry out extremely thoroughly, of course, but it'll also begin or accelerate the process of corrosion. Soaking in rubbing alcohol might be a better idea, but if there are any stickers (covering the UV port on EPROMs, for example), they'll likely dissolve even more quickly in that solvent than just water.
    Feb 2011
    2,226
    10
    Quote Originally Posted by JNZ View Post
    Circuit components are pretty hardy. If they have survived mouse poo I am sure they will survive washing in water. If the stickers have mouse poo on you probably want them to dissolve after taking photos...
    https://www.electronicspoint.com/for...r-rinse.20092/
    G4UGM
    He has to try something to restore these boards. Rather than proposing this liquid or that, might we ask the unusual question "What's best for dissolving solidified mouse poo & wee?"
    I'll wager it isn't alcohol.
    4,645
    Hot soapy water is the way to go, in my experience. No, you will not harm most electronics with it, that's how they get cleaned in industry. The only thing you have to watch for are items that have hollow spaces inside, like DIP switches or trimpots. Blow them out with air before/during drying.
    I dry everything in a forced hot air drying cabinet which I believe was originally intended for some photo process, but a household oven works well too. Set it on the lowest setting and leave the door ajar. Of course, being as how this is mouse mess stuff, you'll want to probably put something on the oven rack *and* wash the oven out afterwards. You can also leave the boards out in the sun on a hot, dry day.
    Dish soap is intended to loosen organics and it most likely the best for mouse poo. As glitch says, remove or be willing to replace pot and dip switches.
