Results 1 to 2 of 2
Thread: MCE2VGA and Amstrad PC1512?
    Default MCE2VGA and Amstrad PC1512?
    Just an idle thought... Has anyone got a PC1512 to output video using an MCE2VGA rather than its original monitor? (You'd have to provide an alternative source of power too, of course).
    The PC1512 video pinout is here - 8-pin DIN socket and (unlike CGA) uses composite sync rather than separate horizontal and vertical sync.
    Mar 2006
    Massachusetts, USA
    1,877
    I can imagine the FPGA can be reprogrammed to accommodate composite sync if it doesn't support it out of of the box. The composite H&V sync pin should be connected to pin 13 on the VGA connector.
    If it doesn't work and the creator doesn't want to support it, then you could try this :
    https://www.aceinnova.com/en/electro...rator-circuit/
