Results 1 to 3 of 3
Thread: IBM Displaywriter printer cable pinouts
    Default IBM Displaywriter printer cable pinouts
    Can anyone help with any information on printer connection pinouts of an Displaywriter? (6580). I finally got an IBM 5218 printer, which I would like to connect to the system, but it is missing a cable. Simple straight -through or nullmodem DB9 cables are not working, and I have already destroyed a Displaywriter's power supply by trying to guess the correct pins by measuring resistances/voltage between different pins, and adjusting the cable.
    The result - 5V power supply in a Displaywriter's PSU is dead. Fortunately I had a parts machine which I was able to take a PSU board from, and Displaywriter works, but I do not have any spare boards left, so no place for errors as well - below - testing the PSU from the parts machine:
    The only information I have found online is the configuration of IBM 5218 printer port pins:
    I know it is a very small chance, maybe someone has an IBM Displaywriter printer cable for sale?
    Feb 2011
    2,425
    10
    You could try a wanted ad in the for sale/wanted section. Also CCTALK/CCTECH list. (google it)
    G4UGM
    Jun 2009
    Hobart, Tasmania, Australia
    162
    Never had my hands on the printer part of a Displaywriter system so not familiar with the cable configuration.
    I'm guessing you've looked at this already? Screen Shot 2019-06-23 at 3.59.03 pm.jpg
    Page from this manual:
    http://bitsavers.org/pdf/ibm/6580_Di...al_May1982.pdf
