Results 1 to 10 of 30
Thread: MS-DOS 2.25: was it ever released or was it vaporware ?
    Default MS-DOS 2.25: was it ever released or was it vaporware ?
    Was MS-DOS 2.25 actually released or was it vaporware ? MS-DOS 2.25 was widely documented to provide early DBCS support for Korean and Japanese character sets and was presumably only released in those markets but there is apparently no known evidence of such a release. There are conflicting release dates for it, some sources claim April 1984 while others claim October 1985. All sources say that MS-DOS 2.25 added INT 21h function 63h (which was originally referred to as "Hongeul" in the DOS source code) though MS-DOS 2.x is known to only support INT 21h functions up to 58h (which was added in MS-DOS 2.11). DOS 3.0 added functions 59h-62h which supposedly are not in MS-DOS 2.25. Could Microsoft have simply put the info out there in an attempt to drum up business in the Far East market ? Could there have been so few OEMs in the region using it that MS-DOS 2.25 is simply lost to time ?
    33,638
    If you could find a PC JX owner, I suspect that you'd also find a copy of 2.25.
    Maybe. The PC JX was also released in Australia and New Zealand so it's unlikely they would have MS-DOS 2.25. Also the PC JX supposedly came with PC DOS 2.1 and as an IBM computer it would have never shipped with anything other than PC DOS. As far as I know there was never a "PC DOS 2.25" as IBM wasn't interested in internationalization at the time.
    6,328
    The PCjx was only released in Australia and New Zealand when it failed in Japan and IBM had much inventory to get rid of, so those came later. The PCjx definitely supported Kanji on day 1, you can see this in the promotional literature. Exactly what DOS version provided that I don't know, but it wasn't DOS 2.1, and it seems unlikely that IBM would go backwards in terms of bundled DOS releasing to an English-speaking country. The PCjx was an enhanced PCjr and likely needed features not present in 2.1. Chuck's advice is relevant.
    33,638
    Hmmm. Could have been an OEM version that never saw the light of day.
    Page 2 mentions PC-DOS 2.25 being sold by Atari
    That's the first I've ever heard of a "PC DOS 2.25" and I worked on PC DOS at IBM. IBM certainly never acknowledged the existence of such a version.
    Did the Atari ST x86 add-on board ever actually come out ? There was a lot of stuff planned during the Tramiel era of Atari which never saw the light of day. Atari also planned on making an Atari 1600XL hybrid system which would have had a 6502 for Atari 800/800XL compatibility and an 80186 for DOS compatibility.
    4,621
    A picture of the disk provided with the IBM JX in Japan shows a printed version label of K2.2. How this compares with the 2.25 is information I do not have.
    http://msibata.org/ibmpc/image/jxdos.jpg
    That's interesting and I wish I had an image of that disk for analysis but one thing to consider: DOS didn't get 3.5" 720KB support until DOS 3.2. Theoretically previous versions of DOS could use half of a 720KB since it would appear like a 360KB floppy to them. The PC Convertible was the first PC that I know of to use a 3.5" 720KB floppy drive and it shipped with PC DOS 3.2.
    33,638
    PC JX was released in 1984 with 3.5" drives:
    Granted, they were 720K, but there you have it. Note also, that said drives are half-height, not the later one-third (of a FH 5.25" slot) height drives. I wouldn't be at all surprised if the drives were also the 26-pin variety.
    4,621
    While the IBM JX started off only able to handle 360kB on its 3.5" drives, the ROM version of MS-DOS 2.11 available with Toshiba T1000 could support 720kB formats on its 3.5" drive.
