Results 1 to 2 of 2
Thread: New user posts
    Default New user posts
    How long before new user posts do not go through moderation ?
    Mar 2009
    Dublin, CA USA
    2,947
    http://www.vcfed.org/forum/announcement.php?f=13&a=10
    See the section at the end about new user posting.
    I am allowing this post through (usually I delete these, since it's clearly available in the announcements section) so that everyone can see it, and be reminded about our etiquette and other such things.
