Results 1 to 4 of 4
Thread: LSI-11 experimentation project
    Default LSI-11 experimentation project
    I haven't touched my DEC stuff in a couple of years, but now getting back to it again.
    In the picture below:
    LSI-11, 32KW RAM, DLV11-J.
    The backplane is from a VT-103. The power supply is from a Rainbow.
    The console goes to a simple level converter (from Sparkfun), which then goes to a T.I. MSP430FR5994 eval board, which then goes to my PC via USB.
    The TI board includes a micro-SD card socket. I wrote an app for the TI board that is like an "intelligent terminal emulator", in combination with Putty running on my PC. The app lets me (for example) load a serial bootloader via ODT, then load/unload images in/out of RAM.
    I have a stand-alone image of Forth working on the setup. The bootloader loads in about 5 seconds (via ODT), the Forth image loads in 10 seconds (in binary; it is 5.5KB). The images are stored on the SD card, or can be dumped to Putty.
    Pete
    Mar 2006
    Salt Lake City, UT, USA
    295
    I love the ingenuity
    Jul 2014
    Germany, near Göttingen
    28
    Thumbs up for this working combination
    If you want to make some further development on it - do you know Joerg Hoppes LSIbox Project?
    http://www.retrocmp.com/projects/lsibox
    Quote Originally Posted by Wildfire View Post
    Thanks! And yes, I had looked at that page recently. I'm now trying to decide on packaging options. I switched to a H9281 4-slot-dual BP, and added an 11/03 switch panel. I have an industrial server PS that is smaller than the Rainbow supply. I may add a period-correct 7-segment display...
    Pete
