Results 21 to 30 of 32
Thread: dead 8032 with strange behaviour
  1. #21
    2,721
    If the reset circuitry doesn't work - then there is no chance of the PET working.
    Solder a normally open pushbutton either across C51 - or between pins 7 and 1 of UD16 (555).
    Under normal circumstances (after the PET has been powered on for 30 seconds or so) measure the voltages/logic levels at:
    UD16 pins 6 and 7 - both should be close to 5V.
    UD16 pin 3 should be LOW.
    UE15 pin 1 should be LOW.
    UE15 pin 2 should be HIGH.
    UD15 pin 5 should be HIGH.
    UD15 pin 6 should be HIGH.
    UB14 pin 40 should be HIGH.
    Depress (and hold) the push-button.
    UD16 pins 6 and 7 - both should be close to 0V.
    UD16 pin 3 should be HIGH.
    UE15 pin 1 should be HIGH.
    UE15 pin 2 should be LOW.
    UD15 pin 5 should be LOW.
    UD15 pin 6 should be LOW.
    UB14 pin 40 should be LOW.
    Release the push-button.
    Capacitor C15 should charge up over a second or so and the signals levels should revert back to what they were initially.
    Please post your results.
    Dec 2012
    São Paulo country, Brazil
    728
    Here the results...
    BTW I haven't a new 74LS17 (UD15) so i replaced it with a 74LS07, should be a 100% replacement
    UD16 pins 6 and 7 - both should be close to 5V.-- 4,84v
    UD16 pin 3 should be LOW. -- HIGH
    UE15 pin 1 should be LOW. -- HIGH
    UE15 pin 2 should be HIGH. -- LOW
    UD15 pin 5 should be HIGH. -- LOW
    UD15 pin 6 should be HIGH. -- LOW
    UB14 pin 40 should be HIGH. -- LOW
    UD16 pins 6 and 7 - both should be close to 0V -- 0V
    UD16 pin 3 should be HIGH. ok
    UE15 pin 1 should be HIGH. ok
    UE15 pin 2 should be LOW. ok
    UD15 pin 5 should be LOW. ok
    UD15 pin 6 should be LOW. ok
    UB14 pin 40 should be LOW. ok
    Oddity of the day: it becomes to make a "fizzle" from the speaker, sometimes, randomly. In first I was worried because it's that kind of noise made by a burning resistor or IC. Strange, because the 6522 isn't in place (I removed 6520s and 6522; they're ok, I tested them, but just in case). I replaced UD5, but the noise continues. Some electrical noise over some line?
  3. #23
    Dec 2012
    728
    EDIT: I changed R24 that seemed bad (actually, after removed I tested it, and it seems ok...) and things get slightly better:
    UD16 pin 3 should be LOW. -- ok
    UE15 pin 1 should be LOW. -- ok
    UE15 pin 2 should be HIGH. -- ok
    UD15 pin 5 should be HIGH. -- ok
    UD15 pin 6
    Now it seems something related with UD15. Tomorrow I will check again the above scheme; I also have some doubts about R25
    No more noise from the speaker.
    Time to sleep!
  4. #24
    2,721
    Based upon your last post I would check the following:
    R15 (1k pull-up to +5V). The 7407/7417 are open collector devices. So if this resistor is open circuit - or the PCB track damaged - then the /RESET signal will never go high.
    UD15 (7417) could be faulty. Yes, I know you have replaced it - but it still could be faulty (unlikely - but possible).
    There is a short circuit somewhere on the /RESET line dragging it to GND/0V/LOW. With the PET switched OFF, measure the resistance from UD15 pin 6 to GND/0V. A low value would indicate the presence of a short circuit - so you will have to look at the PCB carefully with a bright light and a magnifying glass to see where the problem is.
    The fact that you are stating that you get a different result after replacing R24 (even though R24 seems to be OK when it is out of the board) indicates to me potential PCB tracking/soldering issues.
    Dec 2012
    728
    I can't get the rid of the reset circuit, I don't know why.
    The 555 gives strange results at multimeter and probe.
    Pin 6,7 and 3 pulses; pin 3 sometimes pulses, then stays high for a while, then pulses again, apparently randomly.
    I also did some measurement removing the UE15 and UD15, just to focus on the reset circuit... and I also removed UE15 and UD16 sockets and verified there was no short circuits or something wrong under them.
    I tried to chang the three caps: C51 with an 1uF 100v electrolytic, C50 with a 0,1 uF (labelled 104) ceramic and C52 with a 0,01uF (labelled 103) ceramic.
    I have about 2,50 Volts at UD16 pin 6 and 7, but removing the IC I read 4,89 at the socket. --->> Oddity: on the good and working 8032 I read 0v at UD16->pin 6 & 7 after boot ... will check again, but I'm quite sure of that.
    I checked with various (at least 5) different 555.
    I can't see any problem on the PCB and I don't understand what's going on with that. The circuit is quite simple and I expected to fix it quickly....
  6. #26
    Pull out all chips with a /RESET connection.
  7. #27
    Quote Originally Posted by giobbi View Post
    smells like damaged PCB tracks and/or hole metallization damaged making no contact to GND on pin 1 of the 555 and/or surrounding capacitors.
    Solder iron is the worst enemy of any vintage repair.
    Frank
  8. #28
    Dec 2012
    728
    extracting UE15 and UD15 shouldn't cut the /RESET line between 555 and the other chips?
  9. #29
    Dec 2012
    728
    Frank
    I understand...
    Even if I'm quite sure I didn't damage the PCB (I have a good unsoldering station and I take a lot of care doing that; at least I didn't damage any tracks), I will check every solder with a multimeter to be sure; of course there's a problem and it must to be fixed.
  10. #30
    2,721
    You say above that you replaced C51 with an electrolytic. The parts list calls for a low leakage electrolytic - or a tantalum.
    If the capacitor is too leaky - it may not charge up enough to operate the 555.
    Either that, or a faulty PCB...
