Results 1 to 9 of 9
Thread: Dos utility .. ? Exists
    Default Dos utility .. ? Exists
    I have a task where I need to get a byte array (about 180kB) into memory, at a known starting address, in my IBM5155..running DOS 3.3. I have the array as a .Hex file. I want to operate on those bytes with an 8088 assembly language program I can write and and then retrieve the bytes to another .hex file on a floppy.
    Is there a pre-existing DOS software utility where you can open a chosen hex file from disk, load it to memory, starting at a user selected address, and also dump the memory from a known address to floppy as a new .hex file ?
    Obviously I could write a program using a DOS 21H and read and write function calls, but I wondered if there is an existing program that could do it for me ?
    debug. well, unless debug is sitting in the address space you need... but you'd need to do some hex 2 bin shenanigans and convert it...
    Mar 2017
    New Jersey, USA
    469
    If you can get the data converted from hex format to a binary image, you may be able to use DEBUG to load and save. I'm not certain whether any of the N, L or W commands are specific to a particular DOS version but you would use "N filename.ext" or "N C:\dir\filename.ext" to identify the name of the file, and something like "L 8000:0" to load from file, or "W 8000:0" to write data (with BX:CX register pair holding a 32-bit value indicating how many bytes to write).
    This might simplify your search to finding hex2bin and bin2hex converters.
    31,779
    What the two previous posters said.
    DEBUG understands HEX format on input, but there are also converters between HEX and binary format.
    5,943
    If the "load at a very specific memory address" requirement isn't necessary, there are certainly DOS hex editors for binary files. Otherwise, DEBUG comes with every DOS 2.x and later...
    Thank you all for the replies, I will try debug.
    Quote Originally Posted by kgober View Post
    Great, Thanks, DEBUG works like a charm for this task.
    Soon, I need to do the same thing in my SOL-20 running CP/M 2.2. Will DDT do this too where I can open (in this case) a named binary file on disk , read it and select a specific starting address to load it to in RAM ?
    If not, then I would have to use BDOS function calls to open & presumably sequential read the file and place at my selected address. But my CP/M books do not show an exact example of how to do this with an 8080 assembly language routine, so an example of how to do that would help me a lot. (In this case I don't need to write the file back to disk or modify the disk file)
    ...... I have partly answered my last question. DDT can do the same as Debug, but it is a bit more tricky. It is in Digital Research's original DDT document.
    The file can be opened with the I(input) command) then the R command is used. But it has to be a .Hex or .COM file
    If the .BIN file I have is treated and re-named as a .COM file, DDT will load it to RAM . It assumes a starting point of 100H for a .COM file, but you can add an offset with the R command, following the I command, so if R4000 in entered (after executing the I command), it loads the .COM file to RAM starting at 4100H.
    In the meantime I had been working on the 8080 assembly language program to read the file directly from disk to ram, but I have not got it to work......yet.
