Results 11 to 20 of 29
Thread: 25 pin keyboard?
    The 40 pin IC appears to be a 6402 UART so its serial
    But what is the driver chip. The signals look like they might be rs485 or rs422 instead of rs232.
    Dwight
    If it helps, here are some closer shots of those chips on the small board.
    Sep 2006
    Silicon Valley
    2,199
    talk about bad timing. they just bought it on ebay
    https://www.ebay.com/itm/AVL-K69-Key...s/383421528752
    note the same keypad key is missing
  5. #15
    Sep 2006
    Silicon Valley
    2,199
    Quote Originally Posted by SMichelsen View Post
    1488/89 on the left are RS232 transmitter/receivers
  6. #16
    33,691
    18
    I don't see any LEDs or other indicators on the keyboard, so why is the serial communication 2-way? (1488-1489)
    So the power feed must be +12, -12 (note the 7805 regulator, so +5 isn't needed).
    You have RX, TX, Gnd, that makes 5 wires, but there are 9 on the connector. What do the other 4 wires do?
  7. #17
    It's time to sing "it's a small world", or something. That ebay keyboard is the SAME one you've all been looking at. In fact the new owner of the keyboard, who also has a CPU, just now offered it all to me! I am now officially up to my neck in AVL Eagle bits.
  8. #18
    I suspect there may be a clock wire and possibly a data ready wire and a reset. I see lines going directly to the 40 pin chip. Is there a data circuit we can look at for this chip or is it one of those generic AY???? USART parts ( always forget the number).
    Dwight
  9. #19
    33,691
    18
    I think it's this one
  10. #20
    I did some careful offsets and it looks like the traces from the left go between the pins of the 6402. If they went to the pins, some would need to go to the read data.
    It would be much better to look at the board and ohm some of the signals out.
    Dwight
Tags for this Thread
