Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: Nightmare!!!!!!!!!
    Oct 2016
    Cincinnati, Ohio USA
    428
    Wonder what would happen if the LCD panel was placed in a vacuum chamber for awhile.
    I would try sealing the computer in a large plastic bag with a few silica gel bags. If the issue is moisture, that should cure it.
    PCjr, DTK PC-XT Turbo, 386DX 33, 486 laptop, Pentium 120, Pentium III 500, various old laptops, Commodore Colt, all working. I also have a 286 that I need to see if I can repair.
    5,787
    44
    A thought was to dismantle the LCD and place it in a food dehydrator for a week and see what results you get.
    = Excellent space heater
    Aug 2016
    Turin, Italy
    124
    I was thinking to do the same...
    My Idea is to measure humidity and temperature, let the computer home for example for 10 minutes and make a photos.
    Then to put in a vacuum bag with some silica bags in it and wait for some times... I was thinking about a months... let's see!
    Default Deteriorating
    maybe the lamp behind the screen is old and need replacement.
    also check the voltages from the high voltage wiring that goes to the lamp.
    if they are low maybe you need to recap the board.
    I agree with this. I think a replacement is needed.
    5,787
    44
    A weak CCFL will result in either the backlight inverter shutting down due to excessive loading, a pink tint as the tube initially strikes but is low on mercury (it normally consumes the mercury in the tube over its life) or quite simply the screen will be evenly dim and not just in the corners as seen with Tunnel Vision.
